Author Topic: 340 camshaft bearing replacement question  (Read 872 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« on: October 08, 2009 - 11:06:25 PM »
So it turns out the 340 I am working on needs the cam bearings replaced. So I have new bearings and the tool to install them and I am wondering if there is any special order they need to be installed in or any tricks I should know. I know I need to make sure I get them in straight. Thanks.
1996 Dodge Viper GTS Coupe
Offline 71chally416
    • The Streetwalker
Re: 340 camshaft bearing replacement question
« Reply #1 on: October 08, 2009 - 11:12:58 PM »
They install back to front and make sure the oil holes are lined up.
Offline 72hemi
« Reply #2 on: October 09, 2009 - 10:40:12 AM »
Thanks, anything special to remove the old ones?
Offline 71chally416
    • The Streetwalker
« Reply #3 on: October 09, 2009 - 03:42:17 PM »
Just the right tool with the slidehammer and some care and patience.  :2thumbs:
Offline Changin Gears
« Reply #4 on: October 09, 2009 - 06:16:10 PM »
The trick is to get them square with each other.  To do this you need to intall the back 2 with handle out the front and the front 2 with handle out the back (middle doesn't matter).  The insures that the tool is straight and the bearings will end up straight.
Before I got my own tool, when a machine shop would install the bearings, the cam would always be snug when turning.  If you do yourself and take your time the cam will spin easy.
Offline 71chally416
    • The Streetwalker
« Reply #5 on: October 09, 2009 - 07:17:35 PM »
Good idea! That way you have a good reference to make it square with the rod location in the cam journal.  :2thumbs:
« Reply #6 on: October 10, 2009 - 02:32:41 PM »
you will nto be able to replace the rear brg without removing the cam plug & the tranny canot be bolted to the engine while doing this
Basically you have to install from the rear & follow the advice above
