J2D-18DBL goes to a splice that splits it five ways. Ballast resistor, ECU, Bulkhead connector(Ignition run), regulator, and power for electric choke(if you still have/had it). I would start with thoroughly checking for pinched/grounded wires in each of the five ccts, then checking the components, the ballast resistor, column wiring, swapping out the ecu, regulator if you have spares. Good luck, it may take a little time.
