Author Topic: for those who think the 383 is some shadow under a 440  (Read 6132 times)
Offline Changin Gears
Re: for those who think the 383 is some shadow under a 440
« Reply #30 on: October 23, 2009 - 12:08:46 PM »
A reason to build a 383 is not to do the same thing as everyone else (build a 440).  Kinda the reason I'm into Mopar.  Everyone has a Cheby.
Offline the_engineers
« Reply #31 on: October 23, 2009 - 10:13:54 PM »
Same reason I REALLY want a small block 440.  :droolingbounce:
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #32 on: October 24, 2009 - 11:58:48 AM »
You can get 10-1 pistons and like one of my 383's i built,(have 2 fresh ones on engines stands) I used 1967 440HP closed chamber heads, which brings the Comp ratio right up and outperforms open chamber heads.
I thought I had read a write up many years ago that the closed chamber heads were good for bringing the compression ratio up but did not make more power than an open chamber head due to the burn characteristics between the two chambers when the piston was at TDC.
2013 Tige' RZR 343hp
