Author Topic: R/B Roller Cam.  (Read 1489 times)
Offline loco440
R/B Roller Cam.
« on: October 12, 2009 - 03:29:19 AM »
Im sick of the flat tappet cam run in prosedure so looking at going roller cam,who makes the best and what grinds can you get for mild 440s?any pros or cons from any one that has used them at all?
Offline hemiken
Re: R/B Roller Cam.
« Reply #1 on: October 12, 2009 - 05:13:38 AM »
I suggest you pick from one of these camshafts Old Mate :2thumbs:
http://www.lunatipower.com/ProductGroup.aspx?id=290&cid=62
moparniac
Re: R/B Roller Cam.
« Reply #2 on: October 12, 2009 - 06:18:09 AM »
As far as best that's just an opinion... The cam in my challenger was very mild... What are the rest of the engine specs...
Offline loco440
Re: R/B Roller Cam.
« Reply #3 on: October 12, 2009 - 09:12:15 AM »
My engine specs are six pack,440source heads,std manifolds,3.55 gears and a 4 speed and at moment a six pack cam,a manifold stud broke on the 906s at the end under the booster so have to take the head off so may as well rip into it and change the cam and heads while Im under the bonnet.
Offline moper
Re: R/B Roller Cam.
« Reply #4 on: October 12, 2009 - 12:02:14 PM »
I'd go with a hydraulic street roller. Something like the XR274HR-10. Smaller is better in your case. I would not go solid roller unless you tera the engine down and bush the lifter bores.
moparniac
Re: R/B Roller Cam.
« Reply #5 on: October 12, 2009 - 05:34:59 PM »
Why is that? I really don't think that is necessary...
Offline moper
Re: R/B Roller Cam.
« Reply #6 on: October 13, 2009 - 09:47:23 AM »
Matter of opinion. If you've never had a failure that led to the lower end being damaged, then it's usually a hard sell. I have seen it twice. If say a spring fails or loses tension and the pushrod bends the lifters tend to pop out of the bores. On the left side that means all the oil pressure goes out of that bore and none go to the bearings. Unless this happens at idle there is no way to shut the engine down fast enough to avoid damaging the bearings and crank. So bushing to me is critical. It also repairs the lifter bore angles that are very common and allows the control of oil to force more to the bearings. Hydraulic rollers tend to not have that problem with lighter springs and less failure issues with the lifters during street duty.
Re: R/B Roller Cam.
« Reply #7 on: October 13, 2009 - 10:32:06 AM »
moparniac
Re: R/B Roller Cam.
« Reply #8 on: October 14, 2009 - 05:34:08 AM »
Lifter Bore corrections are around $500 these days around here.....  :working:
Offline Hemi Dude
Re: R/B Roller Cam.
« Reply #9 on: October 15, 2009 - 06:05:11 AM »
loco440
I do not have problems you see.... i have ticked the box at the dealership where it said: " Easy to change spark plug option " and i got a HEMI under my hood   :stirpot:
Flat tappet, roller, whatever... MY HEMI RULES... :worshippy   :ylsuper:
'70 Hemi Challenger (modified)
'74 El Camino SS 454
"It takes a Mopar to catch a Mopar"
Offline loco440
Re: R/B Roller Cam.
« Reply #10 on: October 17, 2009 - 02:50:55 AM »
Thanks HEAVY DUDE,we all know Hemi for show 440 for go.
Re: R/B Roller Cam.
« Reply #11 on: October 17, 2009 - 07:04:58 AM »
NOW PLAY NICE! :poopoke: :smilielol: good one.
