Author Topic: 4 speed tranny issue  (Read 734 times)
Offline 4 speed fish
« on: October 12, 2009 - 07:16:32 PM »
Installed rebuild 833 23 spline tranny with  new centerforce clutch.I have grinding going into 3 and 4 gear.Could it be rod alignment.Any ideas. Thanks
Offline Changin Gears
Re: 4 speed tranny issue
« Reply #1 on: October 12, 2009 - 07:36:37 PM »
It's probably not this shifter adjustment if it happens going between 3-4 or 4-3.  My guess is it's internal, the 3/4 slider is the one that tries to fall apart during assembly.
Could be the clutch, if you can go to reverse without grinding, probably not.
« Reply #2 on: October 13, 2009 - 12:27:12 AM »
 I have had nothing but problems with C Force clutches , try eliminating that first
Offline Purple73Cuda
« Reply #3 on: October 13, 2009 - 07:48:50 AM »
When the Centerforce clutch was put in, did the overcenter spring under the dash get disconnected? If not, the "fingers" on the clutch probably got damaged. That is what happened to my 'Cuda. I threw the clutch in the trash and put a McLeod Borg and Beck in. It made a huge difference!
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
