Author Topic: Under the Knife  (Read 2551 times)
Offline the_engineers
Under the Knife
« on: October 13, 2009 - 11:23:25 PM »
Well, now that the weather is starting to turn ugly, I'm taking a hobbist body course through the local college (same course Sprecks took).
The quarter that didn't look too bad actually turned out to be full of rust and bondo.  I didn't get any pics of the grinding/cutting process, but I do have pics of the road to recovery.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Re: Under the Knife
« Reply #1 on: October 14, 2009 - 07:55:28 AM »
I was looking at your pics and noticed that it looks like your rear sway bar is an aftermarket piece like mine(from the way it is bolted to the axle). What kind of bracket attaches to the frame for the end links? Mine used a 'U' bolt that you inserted into and back out of the frame, but I noticed recently that it is starting to pull through. ie stress cracking.  :banghead: Any chance of a pic/explanation if it is different/better?
'The quarter that didn't look too bad actually turned out to be full of rust and bondo.'
At least it didn't go too far. Keep the pics comin'  :popcorn:
Offline nick68
Re: Under the Knife
« Reply #2 on: October 14, 2009 - 08:55:15 AM »
Nice work. Looing real good.
 4 rear shocks ?   :clueless: How does that work out for you.
"Did I mention I hate sanding ? "
Offline loco340cuda
Re: Under the Knife
« Reply #3 on: October 14, 2009 - 10:33:31 AM »
Great picts.  It makes me jelous when I see picts like this becuase it makes me want to do that to my car.  I am so sick of looking at the rusted out lower quarters and crappy paint job on my car.  Kuddos to you for learning how to do it yourself.  :clapping:
Keep the progress picts coming.
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: Under the Knife
« Reply #4 on: October 14, 2009 - 11:46:50 AM »
I believe the two extra shocks are for axle wind-up/shake. Notice the 2"-3" blocks between the axle perch and spring. :2cents:
Re: Under the Knife
« Reply #5 on: October 14, 2009 - 11:55:57 AM »
I'll get a couple of pics tonight.
Brooks
1971 'Cuda 360
Re: Under the Knife
« Reply #6 on: October 14, 2009 - 12:01:26 PM »
Correct.  The extra set of shocks are Just Suspensions "Ground Pounder" set-up.  It absolutely eliminates wheel hop and is virtually invisible when you have a lower quarter panel on the car.  I've thought about spraying them a matte black, but they're not very visible when the car is on the ground.
The lowering blocks are because I'm running SS leaf springs and the car sat funny (for 40 series tires)
Brooks
1971 'Cuda 360
Re: Under the Knife
« Reply #7 on: October 14, 2009 - 11:42:10 PM »
I think we have the same or similar pieces.  Not sure what to do if your U-bolt is pulling through...sounds like a weak frame section  :scared:  You might be able to reinforce that area by welding some 1/8" plate over the section that's cracking.  you must drive the wheels off your car  :burnout:
Brooks
1971 'Cuda 360
Re: Under the Knife
« Reply #8 on: October 14, 2009 - 11:45:32 PM »
Should my end links be tighter?  They are poly, but after looking at the pic, it doesn't seem like they're doing anything.
Brooks
1971 'Cuda 360
Re: Under the Knife
« Reply #9 on: October 15, 2009 - 09:30:00 PM »
Thanks for posting the pics. The brackets are identical to mine, other than mine started to pull through the frame ::). I hope it's my driving style :burnout: and not frame integrity. I do drive it hard. It's difficult not to with a big block 4 speed. :bigsmile: I think I'll weld in some reinforcement as you suggest. Either a flat strip or maybe a 'C' channel to wrap around the frame. Maybe about 6" in length?
Re: Under the Knife
« Reply #10 on: October 15, 2009 - 09:43:01 PM »
That should do it!
Brooks
1971 'Cuda 360
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
Re: Under the Knife
« Reply #11 on: October 15, 2009 - 09:49:25 PM »
Makes me want a 71 cuda.
 :droolingbounce:
Re: Under the Knife
« Reply #12 on: October 16, 2009 - 09:00:35 PM »
My end links are tighter than your appear to be, but as stated before, I am having some issues with that bracket attachment. Not sure if that is related but it is definitely in the same area.
Offline LAA66
Re: Under the Knife
« Reply #13 on: October 16, 2009 - 10:52:13 PM »
 If it's the area I'm thinking, there isn't much meat for that type sway bar attachment . The original mounting is alot better.
 Welding channel around the frame as mentioned would work though just bend it a little for the taper on the frame.
Re: Under the Knife
« Reply #14 on: October 16, 2009 - 11:01:20 PM »
Definitely the same area LAA66, There are holes in my frame that would match up with the two bolts in the bracket on your car. Thanks for the pic. :thumbsup:
