Author Topic: 400 stroker questions  (Read 7640 times)
Offline moper
Re: 400 stroker questions
« Reply #45 on: October 24, 2009 - 10:02:07 AM »
I never minded the big split. I always mind the huge prices...lol. Jamie's a great guy but he isnt in this for a tax shelter or generosity...lol.
Offline Changin Gears
« Reply #46 on: October 24, 2009 - 10:31:35 AM »
The big split  isn't bad for a cruiser, for general aggressive driving it gets old.
« Reply #47 on: October 24, 2009 - 07:42:48 PM »
Brad, the ratio of my stock A833OD is 3.09, 1.65, 1.00 & 0.73.
My Passon HemiOD is 2.65, 1.55, 1.00 & 0.80
like it was already said - try the stock OD unit first as they are dirt cheap and give you an ideaof what you aregetting into.I can say though at 3.73 ratio in the rear, I would not want any lower ratio. 3.91 would be great if you are using an 8-3/4.
Thanks for the feedback! I just bought  and installed a 3:55, - 8 3/4 rear end.  I always figured for a street car with 1st gear when you multiply the rear end x 1st gear ratio I look for 9-9.5. I have a 86 Buick with a 455 and a T-10 in it with 3:90 rear gears . First gear is almost useless!  I take off most of the time in second gear if I'm just driving normal. Really the 833OD is a 3 speed with an overdrive?
Offline moper
« Reply #48 on: October 25, 2009 - 11:27:48 AM »
That's it, yes.
« Reply #49 on: October 25, 2009 - 05:17:56 PM »
the 833 od is the same as the 4 spd with 4 ratios but third gear is the od ratio so you shift it 1-2-4-3 but by flipping the lever on 3-4 the pattern inside the car is the same
« Reply #50 on: October 25, 2009 - 09:13:42 PM »
What ratio's did the regular 833 have? Were they like a T-10 with multiple ratio's or was there just 1? Just curoius! :dunno:
« Reply #51 on: October 26, 2009 - 01:01:09 AM »
5 Different ratios most were 2.66 1st gear , 1 version was 3.09 1st
 the ratios only varied slightly between most of the regular 4 spds
« Reply #52 on: October 26, 2009 - 08:08:17 AM »
Thanks for the info! :2thumbs:
