Author Topic: Parting out 74 Barracuda & 70 Challenger  (Read 11161 times)
Offline Cuda1971
Re: Parting out 74 Barracuda & 70 Challenger
« Reply #45 on: December 23, 2009 - 12:16:30 AM »
Do you have window regulators and brackets (side and quaters)for cuda perhaps?
Thanks and
Merry Christmas
Roger
« Reply #46 on: December 23, 2009 - 11:23:20 AM »
 I'm looking for the fuzzy window regulator that the pen is pointing too that's held on with 2 screws?
Offline Canadian Cuda
« Reply #47 on: December 23, 2009 - 02:11:57 PM »
i need one of the studs in the upper rad support for hood latch plate and two of those little square nuts for attatching the radiator to the rad. supprt, do you have them?
Geoff
70 Cuda 440-4, auto, 8 3/4 sure-grip
Offline vpittman
« Reply #48 on: December 23, 2009 - 06:12:46 PM »
I'm looking for a passenger side wiper arm, if you have one...
Thanks !
Offline knk-mopar-parts
« Reply #49 on: December 28, 2009 - 08:45:15 PM »
Do you have the a pillars and the cross piece that goes on top between the a pillars? I don't know the correct name? I guess i need the entire structure around the windshield except the bottom cowl area.
Already gone!!!!!
« Reply #50 on: December 28, 2009 - 08:47:38 PM »
Thanks and
Merry Christmas
Roger
Hey  Roger I do believe I have everything you need for both 1/4 windows and both door windows. Where you located? Thanks Kevin
« Reply #51 on: December 28, 2009 - 08:49:14 PM »
I think I have them but dont know condition until I check on them. Thanks Kevin
« Reply #52 on: December 28, 2009 - 08:51:38 PM »
I will check and see...Thanks Kevin
« Reply #53 on: December 28, 2009 - 08:54:44 PM »
Thanks !
Yes I will check condition of it.
« Reply #54 on: December 28, 2009 - 08:56:18 PM »
are your wheel well areas toast? I could use some patch work. thanks.
They are pretty rough, what area do you need?
« Reply #55 on: December 28, 2009 - 08:59:08 PM »
Hey IMNCARN82
dont have what your looking for
« Reply #56 on: December 28, 2009 - 09:17:11 PM »
Hi Lo Prestolite horns working?
Offline stephenlocke
« Reply #57 on: December 29, 2009 - 01:04:30 PM »
Hi,
How rusted it the bottom front window section, I have a couple of rusted out parts on my 70 that I need to patch.
These are both near the 2 windshiled wiper mounting holes.
Let me know.
Thanks
Steve
Offline Cuda1971
« Reply #58 on: December 30, 2009 - 08:21:34 AM »
Hi,Great I have send a PM.Do you know if 74 regulators same as 71?
Thanks.
Roger
I have send you a mail.Pm didn't work.
« Last Edit: December 30, 2009 - 04:17:20 PM by Cuda1971 »
Offline femtnmax
« Reply #59 on: January 01, 2010 - 08:53:44 PM »
Hi - for the front sway bar, do you have the two U-shaped brackets that hold the rubber blocks at the front of the sway bar?  I'm not talking about the thick straight pieces that bolt to the K-frame.
Also, for the 70 chally, do you have the hood safety latch that bolts to the underside of the hood?  Has the spring loaded hook and you lift "up" on the flange that sticks forward.  If so, I'd also need the two bolts/washers that hold the latch to the hood.   Thanks.  Phil
« Last Edit: January 01, 2010 - 08:57:11 PM by femtnmax »
Phil
