Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
sanding at my new home
« previous
next »
Print
Pages: [
1
Author
Topic: sanding at my new home (Read 752 times)
mach3107
Jr. Member
on:
October 15, 2009 - 12:15:58 AM »
I'm hopefully going to close on my first house in a couple weeks and I plan on starting to do body work (I've never done any body work before) on my 73 chally in the walk-out basement garage. The basement is dry from what I can tell.
Can I just start sanding the old paint away and not worry about the bare metal or do I need to put some kind of primer on. I can only work on it ever couple of weeks so I'm worried about letting it sit in the nude. It's a 97% solid shell. I want to strip it this winter and fix the couple small spots. Maybe paint if I find the time.
Any tips would be great.
Logged
GreenFish
Sr. Member
Re: sanding at my new home
Reply #1 on:
October 15, 2009 - 07:48:37 AM »
I would keep a rattle can of some primer handy to coat the bare metal. You probably dont need a lot, just enough to keep moisture off the bare metal. You are going to prime eventually anyhow.
Logged
Skeletoil
Jr. Member
Reply #2 on:
December 12, 2009 - 10:35:01 PM »
Be sure to use an enamel primer. Water proof. Laquers aren't. It will be some time before it's in paint. DP 40 by PPG is excellent.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
