W2 heads are amoung the best heads ever for the small blocks But you better have deep pockets ,
they require after buying the latest castings @ $1000 each
-Valves
-springs
- retainers
- locks
- special intake , no 6 pack is available
-Special rockers costing $100 / set or more
- Special headers $800 - $1000
- Special valve covers , the MP ones don`t even fit the W2 head even though that is all they are for
excet to spend 5000-6000 to get them set up
I aree with above that for the power level you are looking into the W2 heads are overkill , a Set of ported 308 castings should get you where you want to be
I would also pass ont he Demon carb , they are Problematic , the Proform series carbs are far Better & are cheapest through Mancini racing, I would approx double the ci to size the carb
you could do a stroker kit in the 340 & take it to 412 or bigger CI
