Author Topic: Reference pictures  (Read 56770 times)
Re: Reference pictures
« Reply #45 on: March 04, 2010 - 10:21:47 PM »
Pic of ink stamping on a NOS 1971 Cuda header upper valence.
Located on driver's side.
http://img695.imageshack.us/img695/126/valence71.jpg
Offline NoMope Greg
« Reply #46 on: March 05, 2010 - 02:00:51 AM »
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline roy282
« Reply #47 on: March 13, 2010 - 05:54:28 PM »
Thought I would share this great web link  Many good  References found here  http://www.iccahome.org/
« Last Edit: March 13, 2010 - 10:19:12 PM by roy282 »
1974 barracuda 360 gone
1968 charger 318 gone
1970 barracuda gran coupe 383 4spd Gator in the garage
« Reply #48 on: May 21, 2010 - 10:10:35 PM »
71 Hemi Cuda Shaker cable grommet hole location.
Same for 70' except 71' had 2 cables coming out instead of one.
71's were a manual operated choke making the second cable.
« Last Edit: September 30, 2012 - 07:06:34 PM by Topcat »
Offline RUSTY Cuda
  • One big step foward!
« Reply #49 on: May 22, 2010 - 08:18:29 AM »
This one gets asked for a lot, 1973 e-brake cables
« Reply #50 on: June 30, 2010 - 11:17:40 PM »
The 4 speed reverse light location on the dash.
« Reply #51 on: June 04, 2011 - 11:14:43 AM »
Posted earlier in another post, these belong here.
Offline usraptr
« Reply #52 on: July 19, 2011 - 07:17:33 PM »
Below is a picture of how the emergency brake cable that goes to the passenger rear wheel, on a '70 'Cuda, is secured to the back of the rear seat housing/body.  If it's been a few years since you removed the original, like me, you might have forgotten where this tab is attached, I did.  I searched pics high and low on numerous sites and couldn't find where this was attached.  The picture in the instructions and motor manual are vague to say the least.  It took my mechanic son 30 seconds, naturally, to notice the raised/threaded  bracket.  I kept looking rearward in the area of the axle instead of turning around and looking at the body.   :banghead:  :dunno:
(Edited 8-1-17)
« Reply #53 on: July 19, 2011 - 11:28:49 PM »
Idle solenoid p/n's
3514520 Early (AVS)
3549318 Late (AVS)
DR1114421
70 440 4737S,4739S, 4741S, 4740S
Hex head with cap, no integral bracket
3514892 (AVS)
DR1114442
70 340 4936S, 4937S
Round head, no integral bracket
3438303 (AVS)
DR1114442 or DR1114447 (Have reports of both)
70 440 4738S
71 440 4968S
3438777 (Holley)
DR1114441
71 383 4667A, 4734A, 4668A, 4735A, 6191A, 6193A
Hex head with cap, no integral bracket, but includes wiring harness
2875975 (Holley, AFB)
DR1114429
70 440+6 4375A, 4734A, 4376A, 4144A
70 340+6 4791A, 4792A
70 426 4745S, 4746S
71 426 4969S, 4970S
Round head with integral bracket
3438338 (Holley)
DR1114443
71 440+6 4669A, 4670A
Hex head with cap, and integral bracket
3412059 (Holley)
DR1114420
69 440+6
3438333 (Same as 2875975) (TQ)
DR1114429
71 340 4972S, 4973S
Offline gtx6970
    • A+M Hightech Automotive
« Reply #54 on: August 22, 2011 - 11:04:27 AM »
Dec 1969 SBD - 1970 Challenger 340 - LA plant 3.23 open rear axle
Bill Allphin
What can we do for your car.
Offline gtx6970
« Reply #55 on: August 22, 2011 - 11:06:10 AM »
1970 Cuda tail panel location print
Bill Allphin
Offline usraptr
« Reply #56 on: October 01, 2011 - 04:26:09 PM »
Recently finished re-doing the rear drum brakes on my '70 'Cuda.  Here are some pictures of the the spring connections, hardware, etc. in case you forgot  how yours went back together.  The red stripe on the brake drum was applied with a paint brush as per factory.  Since everything I have read said it was applied on the assembly line, I was not real careful about "staying within the lines" so to speak.  I took numerous pictures before I took the brakes apart.  The new brakes/springs/hardware are attached exactly as they were before dis-assembly.  Of course there is no guarantee that the last person who worked on the brakes put them back correctly, if they had even been worked since being installed at the factory.
« Last Edit: July 02, 2012 - 11:41:43 AM by usraptr »
(Edited 8-1-17)
Offline TinCuda
    • 'Cuda
« Reply #57 on: October 31, 2011 - 03:36:22 PM »
Do you have a print for the 'Cuda and the "by Plymouth" layout?
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
« Reply #58 on: April 30, 2012 - 08:57:58 PM »
4 speed Center Console bracket location.
« Reply #59 on: May 08, 2012 - 10:01:38 PM »
Correct "Shaggy" insulation on my car when it was taken apart.
Nobody offers it as a reproduction to my knowledge.
