Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Archives
(Moderator:
Chryco Psycho
Reference pictures
« previous
next »
Print
Pages:
1
3
4
5
6
Author
Topic: Reference pictures (Read 56771 times)
cwestra
Sr. Member
Re: Reference pictures
Reply #60 on:
July 02, 2012 - 07:20:18 AM »
Eyebrow Spoiler AAR fender hole locations (passenger side fender shown):
Horizontal dimensions are 2-1/2" and 6-3/16".
Vertical dimensions are 2-1/2" and 4-1/8".
Remaining hole on the valance can be roughly determined from these.
Logged
Corey - in Northern Indiana
Topcat
C-C.com Expert
Member since 9/16/04
Reply #61 on:
September 30, 2012 - 07:25:40 PM »
Master Cylinder Bore Diameter Chart.
This is important if you are going back to OEM disc brakes.
Those that have posted here on this thread in the past, please review your attachment and re-post it using an uploader such as Imageshack so it won't be discarded.
Logged
Topcat
C-C.com Expert
Reply #62 on:
September 30, 2012 - 07:31:28 PM »
4 speed Brake pedal/Clutch assembly drawing:
Logged
Topcat
C-C.com Expert
Reply #63 on:
September 30, 2012 - 07:38:12 PM »
Side Passenger Door Glass assembly:
Logged
Topcat
C-C.com Expert
Reply #64 on:
September 30, 2012 - 07:52:34 PM »
Non A/C Heater Cable Layout. Notice the picture of the special "J" Hook on the lower right that is required to correctly mount the heater box on the Passenger side.
Logged
Topcat
C-C.com Expert
Reply #65 on:
September 30, 2012 - 07:56:45 PM »
Rear Window De-fogger.
Logged
Topcat
C-C.com Expert
Reply #66 on:
September 30, 2012 - 08:02:51 PM »
Organosol Paint Code:
Logged
burdar
Sr. Resident
Reply #67 on:
November 25, 2012 - 08:26:54 PM »
I was asked to post this here. It shows the areas that I had to trim on my Ultimate Rides dash pad in order to get it to fit. You may or may not have to trim these areas. Every pad seems to be a little different.
Original center speaker opening....no vinyl down inside rectangular opening.
Had to trim vinyl/foam out of this area so the speaker cover would fit. Screw holes were also off and had to redrill them.
This is a bad pic but it shows the right hand side of the dash where it lines up with the dash frame.(the frame is on the top...the pad is on the bottom) The red lines should be lined up. There is a lot of excess foam where the blue arrow is pointing. By trimming the foam away on the inside, the pad will move to the left and line up closer to the dash frame.
Logged
Topcat
C-C.com Expert
Reply #68 on:
November 25, 2012 - 09:44:23 PM »
Speedometer cable clips.
Very hard to find the plastic part. Try junk yards if you're in need of one. Not reproduced.
http://www.cuda-challenger.com/cc/index.php?topic=88966.msg881986#msg881986
Logged
Topcat
C-C.com Expert
Reply #69 on:
November 27, 2012 - 10:33:56 PM »
Speedometer cable routing & Plstic clip.
Logged
Topcat
C-C.com Expert
Reply #70 on:
November 30, 2012 - 09:46:15 PM »
B & E bodies used different length brake booster push rods for the Hemi Bendix brake booster.
The E body used the longer length as shown in the picture.
Logged
elmoska
Jr. Member
Reply #71 on:
December 24, 2012 - 09:10:56 AM »
Quote from: Topcat on September 30, 2012 - 07:56:45 PM
do you have more picture of this casing before you put it in
Logged
1974 challenger on its way..
anlauto
Permanent Resident
I'm Alan G...I'm a Mopar Addict
Reply #72 on:
December 24, 2012 - 09:16:10 AM »
Quote from: elmoska on December 24, 2012 - 09:10:56 AM
That is a picture of the "WORLD FAMOUS BARRELCUDA" I don't have any more pictures of the unit, but they do make a reproduction of it.
Logged
elmoska
Jr. Member
Reply #73 on:
December 24, 2012 - 10:39:09 AM »
look like thats all i have .. and the blower seems to have the same bolt patern as the speaker...
Logged
Suulan1
Jr. Member
Reply #74 on:
March 05, 2013 - 08:00:07 AM »
Hi!
I wonder if anyone could take some measurements or rather a picture of the T/A 340 six pack fender decal size AND location
I have to make those myself since the engine in my car is a 392 4barrel
Logged
Print
Pages:
1
3
4
5
6
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Archives
(Moderator:
Chryco Psycho
Reference pictures
