1970 AAR cuda $ 47,K
Author Topic: 1970 AAR cuda $ 47,K  (Read 1486 times)
Offline hulmule
« on: October 16, 2009 - 09:09:53 AM »
TRUE AAR .  The car has been completely gone through.  The car is yellow, black interior, auto, ralley gauges, and more.  Nice build sheet. Have T/A tag
JUST TOO MUCH TOO LIST.  Have all receipts for everything. Call with any questions.
Body - car has all original panels except for new trunk pan installed. Has original dip primer from factory still underneath.
. Interior- All redone ,new dash pad, gauges-new quartz clock, new tach (Real Time Engineering) , seats ,foams, covers, headliner, carpet ,etc
.  Suspension all new front end pieces (PST), brakes, calipers, master cylinder, rotors all stainless steel lines, all new shocks T/A steering box redone with Firm feel from Steer-n-Gear, front end alignment.
Drive train - 340 T/A block completely rebuilt, top to bottom.  Transmission completely redone, new converter, U joints and balanced drive shaft.  Rear end all rebuilt and detailed with 3:55 gears..Carbs redone with new Pro Max kits . New gas tank and  stainless steel lines. New starter, radiator, alternator, power steering pump. Complete new exhaust and tips, wiring harnesses, electronic ignition.  motor or transmission not original .It’s a T/A Block with all the correct number parts.  I.E. Carbs, exhaust manifolds, radiator, etc.
$47,000 or best offer. Call   (440) 254-3708  (EST) or email at  par12730@sbcglobal.net
« Last Edit: October 16, 2009 - 09:11:59 AM by hulmule »
Offline Super Blue 72
    • Phil's Super Blue '72
Re: 1970 AAR cuda $ 47,K
« Reply #1 on: October 16, 2009 - 09:19:46 AM »
Great looking car!  If I had the $$$ that would be in my driveway!  :grinyes:
Offline 1BADFISH™
« Reply #2 on: October 16, 2009 - 01:36:00 PM »
Wow! Wish I had the money too....interested in any trades?
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
