Author Topic: starting problem  (Read 772 times)
Offline HAWS
starting problem
« on: October 16, 2009 - 10:45:00 AM »
hello, I have this problem when trying to start my 70 Cuda.  I get this clicking sound, like the battery is low. So I replaced the battery, starter, starter relay, both ignition switches( one where the key goes, and the one down in the steering column. It still clicks when I turn the key?? I ran a wire from the starter relay to a toggle switc, and it atarts fine???? Any help would be appreciated..Harry
Re: starting problem
« Reply #1 on: October 16, 2009 - 12:10:49 PM »
it could be bad conacts at the fire wall , bootom of the column or inside the actual switch , you could plug another switch into teh column plug to see of ot works that way
« Reply #2 on: October 16, 2009 - 09:09:40 PM »
Check the bulkhead connector as CP suggests and also check to make sure the battery negative post has a good solid body ground.
