Author Topic: 340 engine questions  (Read 1120 times)
Offline jmartin99
« on: October 16, 2009 - 02:39:11 PM »
I am putting together a 340 for a friends '72 Challenger.  What is the easiest way to prime the oil system before the first startup?  I know with small block chevys you just pull the distributor and put an adapter in the hole and spin it with a drill.
Also, the second and fourth main cap bolts have threaded holes in them.  Is this for some kind of windage tray?  Did it come with one stock?  I dont have one and wondered if I should be looking for one.
Thanks!
Jeff :cheers:
Offline bb71challenger
Re: 340 engine questions
« Reply #1 on: October 16, 2009 - 02:58:31 PM »
The same thing applies for Dodge engines. Get the adapter and use a good strong drill. Turn the whole engine slowly while priming the engine to assure the oil gets everywhere.
*Brett*
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: October 16, 2009 - 03:35:07 PM »
Mopar has a tool that is basically a 6 sided rod that you can chuck in a drill and prime the system. I have one and it works great. As for the 2nd question, yes 340's had a windage tray from the factory and thats what those holes are for.
1996 Dodge Viper GTS Coupe
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #3 on: October 16, 2009 - 05:08:11 PM »
Thanks!
Jeff :cheers:
yes they are for a windage tray,,and i would recomend trying to find one
72rtchallenger
what happens in the garage
stays in the garage
« Reply #4 on: October 16, 2009 - 05:09:23 PM »
Mopar / Mancinis still have the windage trays available new
Offline 71chally416
    • The Streetwalker
« Reply #5 on: October 16, 2009 - 05:26:20 PM »
Assuming you have bought a new hardened oil pump drive (you should have) take the old one and grind all the teeth off the gear and then clean it up good. That makes a great oil prime shaft. I use a speed wrench with a screwdriver socket that will fit down in the hole where the distributor blade goes.  :2thumbs:
Offline ShelbyDogg
« Reply #6 on: October 16, 2009 - 08:04:46 PM »
Before you start turning the pump, take off the oil filter and pump some oil down into the pump side hole.  Fill the filter up then spill it on.  If you don't prime the pump, youl'll be spinning that shaft forever before you get any suction to the pan.
Offline jmartin99
« Reply #7 on: October 17, 2009 - 03:00:27 PM »
Thanks for the inputs guys!!   :cheers:
I found the windage tray, it was with the oil pan.
This site rocks!  :ylsuper:
Jeff
