Author Topic: Flex plate mounting direction  (Read 798 times)
Offline shadango
« on: October 16, 2009 - 05:38:25 PM »
Ok
Getting geared up to reinstall the tranny this weekend.....
I want to make sure that I am mounting the flex plate right.
Here is how the old one was mounted......the "dish" in the center faces out so the flex plate mounting ears are closer to the engine block.  Is this correct?
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: Flex plate mounting direction
« Reply #1 on: October 16, 2009 - 05:50:46 PM »
looks right, and i assume your aware that when you bolt it to the torque converter that the 4 bolt holes on the ears only line up one way on the converter,,you may want to mark it while you have it out  :2cents:
72rtchallenger
what happens in the garage
stays in the garage
Offline shadango
« Reply #2 on: October 16, 2009 - 06:17:24 PM »
Thanks!    :2thumbs:
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #3 on: October 16, 2009 - 06:54:41 PM »
Definitely mark it while you have it out. if not you'll be pulling out your hair!! :pullinghair:
                                                   Matt B.
Matt
  • 72 to 70 clone
    • cardomain
« Reply #4 on: October 16, 2009 - 07:38:39 PM »
are you putting the converter on the trans ? make sure if you do it drops in 3 times when putting it onto the shaft of the tranny,..
72rtchallenger
stays in the garage
« Reply #5 on: October 19, 2009 - 02:51:21 AM »
the boot pattern makes it impossible to go on backwards & yes the ears should be closer to the block
Offline shadango
« Reply #6 on: October 19, 2009 - 05:59:00 AM »
Thanks guys...she's in!
