Author Topic: Gran Coupe  (Read 10802 times)
Offline 383barracuda
  • 383HP 4 Pistol
    • BarraCuda-GranCoupe
Re: Gran Coupe
« Reply #15 on: November 21, 2009 - 11:54:54 AM »
The Barracuda is back home.
They put on the vinyl and now I can build it up.  :woohoo:
Some pics of today's work.
This is gone take a lot of time, resto of the headliner. It's in 3 pieces and I don't know at the moment how to fix it. I think with polyesther.  :clueless:  :1zhelp:
'70 BarraCuda - Gran Coupe 383hp 4 pistol #match
'68 Fury Fast top coupe 383hp 727 #match
'72 Sunbeam Avenger(Plymouth Cricket) 98cui 4 speed
'96 Honda Accord 2.2 vtec
I like to die in my sleep like my uncle from australia
not screaming and yelling like his passengers !!!
Offline 70shaker6pk
Re: Gran Coupe
« Reply #16 on: November 22, 2009 - 09:23:20 AM »
Really like the how the vinyl top looks,   it breaks up all that color.
'JS23V0B'  1970 Challenger R/T N96 440 Six Pack
Offline the_engineers
Re: Gran Coupe
« Reply #17 on: November 23, 2009 - 09:37:52 PM »
Looks absolutely fantastic so far!  :2thumbs:
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
  • 383HP 4 Pistol
Re: Gran Coupe
« Reply #18 on: January 12, 2010 - 10:45:12 AM »
A little up-date.
I'm doing a lot of parts. Blasting and after that powdercoating.
At this moment I'm quiet busy with the headliner. Next week the pictures.
I have to order some parts in the US and after that I can build up the rear axle.
Next week I want to bring the engine to the machineshop. I think they need it for two weeks.Than the fun part is beginning. Build up the engine  :woohoo:
Some pictures from 30-12-2009. http://s57.photobucket.com/albums/g217/rebenk/Parts%2030-12-2009/?start=all
Offline 70burntorangeT/A
Re: Gran Coupe
« Reply #19 on: January 12, 2010 - 11:57:49 AM »
Are you having any problems with the headliner? My challenger has an SE headliner in it which is the same type of headliner as you have and mine was pretty bad to start with. If you have any questions about it i might beable to help you with it.
66 f-100 black  240 straight 6  3 on the tree.....currently blown up :(
70 challenger burnt orange 440 727 3:23-weekend cruizer
  • 383HP 4 Pistol
Re: Gran Coupe
« Reply #20 on: January 12, 2010 - 03:09:46 PM »
I'm gone try to repair the headliner with fiberglas. Only the broken parts I will repair with it. After that I replace the headliner to fix the corners. Maybe you got any other suggestion?
Tonight I made a model for the headliner to put the headliner on outside the car. I hope it will work this way.
And some more pics, http://s57.photobucket.com/albums/g217/rebenk/Headliner/
Re: Gran Coupe
« Reply #21 on: January 12, 2010 - 05:14:44 PM »
Nice little thing you got made there...if your headliner was all bent and warped as mine was you can use that model you have made and spray the headliner with a water bottle (just get it damp) and let it dry and it should take shape to your mold....if that doesnt work you can take some stock headliner bows and use some fine wire and run the wire thru the holes in the headliner and tie the headliner biws to the back of the headliner and that will help keep it in shape too. also...make sure that the overhead console fits good before you stick it in the car...we didnt realize that my console was warped untill we stuck it in the car then we had to pull everything back out and do it again.
Re: Gran Coupe
« Reply #22 on: January 12, 2010 - 05:19:53 PM »
and using material that is a little bit thicker then stock will help hide some of the imperfections and places that you have repaired
Offline hezzel
  • Matching numbers 383 Magnum ,727 at and 3:23 rear
Re: Gran Coupe
« Reply #23 on: January 13, 2010 - 06:19:34 AM »
1971 Dodge Challenger R/T
2019 Toyota Rav4 Hybrid
  • 383HP 4 Pistol
Re: Gran Coupe
« Reply #24 on: January 16, 2010 - 04:50:39 AM »
Thanks for your information  :thumbsup:
Today I'm looking with a guy that works everyday with fiberglass. He will help me with the headliner.
I have order the material in Canada. It's pretty thick, looks good and original.
Re: Gran Coupe
« Reply #25 on: January 16, 2010 - 11:10:35 AM »
the only reason i didnt go original material is because of how much more expensive it was. plus basically no one will know the difference anyways
Re: Gran Coupe
« Reply #26 on: January 16, 2010 - 11:57:17 AM »
Seeing as you went to a lot of effort to stiffen up the body, you may want to consider reinforcing the k-member/steering box mounting as well with gussets and seam welds. :2cents:
Looks like your ride is progressing nicely!  :2thumbs:
  • 383HP 4 Pistol
Re: Gran Coupe
« Reply #27 on: February 23, 2010 - 02:41:40 AM »
@ Dodj, I control all the weldings on the K-member. At some placec I weld it again.
Little progress voor this moment.
  • 383HP 4 Pistol
Re: Gran Coupe
« Reply #28 on: February 23, 2010 - 02:47:29 AM »
Also do the steering colom. I change it from manual steering to power steering. I use a other steering colom as donor.
All the parts are powdercoated.
Here are some some more pics: http://s57.photobucket.com/albums/g217/rebenk/Steering%20colom/?start=all
Offline dutch
Re: Gran Coupe
« Reply #29 on: February 23, 2010 - 01:08:29 PM »
nice progress Henk  :cooldancing:    yer gonna beat me by a year or two....  :swear: :bigsmile:
*** Bart ***
