Author Topic: Oil Pressure Question  (Read 1274 times)
Offline cwestra
« on: October 17, 2009 - 09:27:45 AM »
I'm getting set to fire up my freshly rebuilt 340 engine.  If I crank the engine (with spark plugs removed) should I be able to see some movement on the oil pressure gage?  If so, approximately how long would it take to see the needle move.  I am just trying to confirm that the gage works and that oil is being pumped before I ignite the engine.
Corey - in Northern Indiana
Offline Changin Gears
Re: Oil Pressure Question
« Reply #1 on: October 17, 2009 - 09:47:50 AM »
You really don't want to do that, cranking a new engine/cam shaft could wipe a cam lobe.  Typically the carb is filled with gas so you don't have to crank a new motor very long before it lights.  A better way to check would be to pre-lube by driving the oil pump with a drill.
Offline cwestra
« Reply #2 on: October 17, 2009 - 09:52:26 AM »
I understand.  Where is the best place to get hold of a priming shaft quickly?
« Reply #3 on: October 17, 2009 - 10:55:55 AM »
You could make one out of an old oil pump drive or allen wrench.  I made one once out of a piece round steel (30 years ago), ground away the everything that didn't look like an oil pump drive.
moparniac
« Reply #4 on: October 17, 2009 - 11:06:38 AM »
with the valve covers off also....  :2thumbs:
Offline tactransman
« Reply #5 on: October 17, 2009 - 11:33:36 AM »
http://www.summitracing.com/parts/DCC-4286800/
Terry-tactransman
Union, Mo.
Offline cwestra
« Reply #6 on: October 17, 2009 - 11:34:41 AM »
I actually just got back from Menards with some steel stock so I could do just that, make one.  Thanks.
Offline cwestra
« Reply #7 on: October 17, 2009 - 11:36:05 AM »
Is that for a visual, to see that oil is going all the way through or something else?
Offline 422STROKER
  • Member Since 6/3/06
« Reply #8 on: October 17, 2009 - 11:38:38 AM »
You need to rotate the engine a bit to do both sides.
Tom :2thumbs:
Tom
Offline cwestra
« Reply #9 on: October 17, 2009 - 11:38:58 AM »
Thanks.  Going to try and get something today, though.  That's a good price.
Offline cwestra
« Reply #10 on: October 17, 2009 - 11:39:53 AM »
Tom :2thumbs:
Offline moper
« Reply #11 on: October 17, 2009 - 11:53:19 AM »
the heads only get oil for a few degrees each crank rotation by design, and only one side at a time... so you have to turn the engine while turnign the priming shaft and look for oil in each head.
Offline tactransman
« Reply #12 on: October 17, 2009 - 12:00:00 PM »
That's what I thought too,you can't make one for that,but if you need it today.......... good luck making one,I am sure it will work out fine.  :cheers:
Terry-tactransman
Union, Mo.
Offline 422STROKER
« Reply #13 on: October 17, 2009 - 12:58:22 PM »
That's what I meant. :smilielol:
Tom :icon16:
Tom
Offline cwestra
« Reply #14 on: October 17, 2009 - 03:08:18 PM »
Great.  Thanks everyone.
