Author Topic: 71 Challenger - Body Bumper kit  (Read 1761 times)
Offline Born2Run
« on: October 17, 2009 - 04:25:45 PM »
Purchased a body bumper kit for my 71 Challenger.
The kit contained:
(4) "taller" rubber bumpers w/ part no. 2784714
(2) "shorter" rubber bumpers w/ part no. 3443645
See attached pic.
I'm trying to determine the locations for these bumpers.
I believe the (4) "taller" 2784714 bumpers are used on the rear, outside corners of the hood and trunk lid.  Is this correct?
I'm not sure where the "shorter" 3443645 bumpers should be used.
Can anyone provide some guidance on the locations for these bumpers?
Thanks.
Rich
« Last Edit: October 17, 2009 - 04:28:02 PM by Born2Run »
70 Challenger R/T (JS23N0B) FC7 V1W V9Y H6XW
71 Challenger R/T (JS23N1B) FY1 V1X V6X H6X9
Offline FY1 RT SE
Re: 71 Challenger - Body Bumper kit
« Reply #1 on: October 17, 2009 - 05:51:49 PM »
The kit contained:
See attached pic.
Thanks.
Rich
Offline Born2Run
« Reply #2 on: October 17, 2009 - 07:39:08 PM »
Thanks FY1 :cheers:
You confirmed my suspicions regarding the 2784714 bumper locations.
Any idea on the "shorter" 3443645 bumper locations?
They are the same diameter as the 2784714 bumpers ... just slightly shorter.
Thanks.
Rich
Offline FY1 RT SE
« Reply #3 on: October 18, 2009 - 12:54:45 AM »
Thanks FY1 :cheers:
Thanks.
Rich
The only place I see a listing for those is under 71 Plymouth B Body.
Offline Born2Run
« Reply #4 on: October 19, 2009 - 07:35:51 PM »
Thanks again FY1.
Sounds like I don't need the 3443645 bumpers.
May have been included in the kit by mistake.
 :cheers:
Rich
« Reply #5 on: October 20, 2009 - 10:28:48 AM »
Rubber bumpers for the glovebox door are included in the body bumper kit.  That is probably where they go.
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #6 on: April 29, 2013 - 07:15:43 PM »
Sorry for resurrecting this 3.5 year old post, but I was hoping that someone might have the photo(s) specifically for where the hood bumpers go (two #2784714, one 2900266).  Don't know if '71 is different than '70, or if Rallye/Power Bulge vs. Shaker/Flat makes a difference.  Thanks.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline SBDave
« Reply #7 on: October 05, 2016 - 08:52:01 PM »
Ah this thread has the info I'm looking for!  Also does the tall round bumper ( .875" diameter and about .730" tall) with a part number 30135066 go at the rear center of the hood?  Same deal where I bought a bumper kit and there were almost none on my car to match up.
My car is a 73 Barracuda if that matters
Thanks y'all!
Offline anlauto
« Reply #8 on: October 05, 2016 - 09:09:22 PM »
Yes, tall one goes in the center of the hood :2cents:
