Author Topic: In a 340, where does this go???  (Read 809 times)
Offline jmartin99
« on: October 18, 2009 - 11:02:03 AM »
I am putting together a 340 for a friend for his '72 Challenger. He brought it to me in pieces ready to go together.  I found this bolt in the bag of bolts and I have no idea where it goes.  :clueless:
It is a 5/16 bolt about 3/4" long. The hole goes all the way through it.
Thanks!
Jeff
Offline vinb
Re: In a 340, where does this go???
« Reply #1 on: October 18, 2009 - 11:28:24 AM »
Small block upper cam thrust plate, put it in the upper left hole.
That lets oil to get to the timing chain..
Offline jmartin99
« Reply #2 on: October 18, 2009 - 12:42:29 PM »
Okay,  I have three other bolts the same size that I have in the thrust plate right now along with an oil shield that the bottom left bolt goes through and a tang from the shield sticks into the bottom right hole in the thrust plate.  This is how the service manual showed that it should go.  Do I leave the shield in place and replace the top left bolt?
Thanks!
Jeff
Offline vinb
« Reply #3 on: October 18, 2009 - 03:05:41 PM »
I would leave the bolt in and use the deflector shield...
Some guy's leave the bolt out , your choice...
Offline moper
« Reply #4 on: October 19, 2009 - 11:33:36 AM »
Yup... was said... upper cam retainer plate bolt.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #5 on: October 19, 2009 - 11:05:32 PM »
Ok, once I saw this thread I got a little freaked out and still am. I am in the middle of a 1970 340 that had never been apart before I got my hands on it and there is no hole in any of the four bolts for the cam thrust plate, so what gives?  :dunno:
1996 Dodge Viper GTS Coupe
Offline 71chally416
    • The Streetwalker
« Reply #6 on: October 20, 2009 - 12:16:29 AM »
Somebody screwed up on the assembly line.   :grinyes:
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
« Reply #7 on: October 20, 2009 - 10:58:24 AM »
It works without the special bolt also. Maybe not 300000miles but it works. Remember to use the shield, it really helps.
Offline 72hemi
« Reply #8 on: October 20, 2009 - 11:01:15 AM »
So should I drill one of the bolts (I have a bridgeport mill so making sure the hole is centered is not a big deal)? If so what diamter is the hole? Should I leave the bolt out? What does this shield look like and where can I get one?
Offline the_engineers
« Reply #9 on: October 20, 2009 - 12:14:50 PM »
I drilled one on my mini-lathe...I think I went 3/32"
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline moper
« Reply #10 on: October 20, 2009 - 12:25:24 PM »
Just leave the pass side upper bolt out. Mopar did this on later assemblies.
