This is true so long as the motor needs the extra A/F--like if its big cubic inches or has a steep gear, 3.55, 3.91, 4.10....maybe even 3.23.
You keep putting in lighter springs until you get a bog on WOT, you then put the next heavier spring back in and if it never bogs then that is the spring to use.
