Author Topic: Seeping oil from aluminum mopar valve covers  (Read 5674 times)
Offline shadango
Re: Seeping oil from aluminum mopar valve covers
« Reply #15 on: December 30, 2009 - 12:42:56 AM »
Thanks guys.  No, its definitely seeping through the sideof the cover.  I can watch it form a drop and then the drop runs.
Offline Aussie Challenger
« Reply #16 on: December 30, 2009 - 02:08:19 AM »
  With the rocker cover off and clean, turn it on its side with the leaking side down, pour in a small amount of gas over the inside area where it may be leaking, if it is porous you will see it. Depending what you find you may be able to repair or use a quality paint like Hemiken suggested.   :2thumbs:
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #17 on: December 30, 2009 - 06:47:27 AM »
OK, found some info.....
You can look up and find the properties with either "GLYPTAL PAINT" or "GE Glyptol electric motor paint" may be the same thing :2thumbs: good luck.
http://www.eastwood.com/glyptal-red-brush-on-1-qt.html
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline shadango
« Reply #18 on: December 30, 2009 - 07:23:23 AM »
Thanks torredcuda...
Ouch...$50 (plus shipping) ....
I may have to live with the seepage unless I can find a less pricey alternative. Or just spring for brand new covers.....grrrrrrrrrr.
Offline hemiken
« Reply #19 on: December 30, 2009 - 07:46:31 AM »
There may be another solution, i am pretty sure that a product called VHT actually make a spray bomb for this exact application, you could do a search but again i do not know what they would call the paint ? sorry.
Offline hemiken
« Reply #20 on: December 30, 2009 - 08:16:29 AM »
I had a quick look and this looks like it would do the job for what you want, i would contact to company to double check it would be sufficient :2thumbs:
http://www.vhtpaint.com/barrelpaint.html
Offline 71Plym
  • 1971 B2 Cuda
« Reply #21 on: December 30, 2009 - 03:56:08 PM »
I had a similar leak with those aluminum valve covers.  Upon very close inspection, it turned out to be a hairline crack.  They were brand new and tried to return them to Mopar Performance.  They basically said too bad; no return.  I used JB Weld on the crack and the leak stopped.
Offline torredcuda
« Reply #22 on: December 30, 2009 - 05:16:02 PM »
Find a different source for the stuff as I`m sure eastwood marks it up.Your local auto parts might be able to get it for you.
Jeff
Offline shadango
« Reply #23 on: March 29, 2010 - 09:51:35 PM »
Ok, resurrecting this old thread yet again just to update.
I did my first oil change on the fish and all went well,  and I was feeling industrious....
 :working:
........so I took the leaking valve cover off to investigate the annoying seepage again.
Turns out that there are two hairline cracks, each about a half inch long.....if I held it up to a light, one I could see some light thru, the other not....so I degreased and cleaned , then roughed it up and then used a product called "Q Bond".  its this powder you put on the area needing repair and then add drops of what is basically super glue.  This stuff dries rock hard and very strong from what I can see.....we'll see how it holds up...the best part is that it was dry and ready to reinstall in 10 minutes.  I reassembled but am going to let it sit til tomorrow evening before firing her up.
We'll see I guess.     :dunno:
Offline the_engineers
« Reply #24 on: March 29, 2010 - 10:16:36 PM »
Def let us know on that!
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline Daves74chally
  • "Yea.... I need another new pair of tires"
« Reply #25 on: March 29, 2010 - 11:00:42 PM »
Q bond is some real tough stuff, used that on more than one occasion.
1974 Dodge Challenger 414 stroker, 727 trans, 8 3/4 posi [OO/`````\OO]
Buffalo, NY
Offline shadango
« Reply #26 on: March 30, 2010 - 05:21:01 AM »
Well that makes me feel better for sure.....I wasnt sure when I bought it.....the demo stuff they have for it is impressive, but it was like $18 for two tubes of super glue and two tubes of "magic powder".....LOL......I was skeptical at first but the guy at NAPA swore by it....so I bought it "just in case"....didnt have anything in mind at the time to repair with it.....
It claims to be heat resistant up to like 385 degrees, oil resistant, blah blah blah.....what sold me is how fast the guy said it would set up.  JB Weld has saved my butt a few times, but it takes forever to set up.
I will definately post after I run it and then longer term results.  If $18 can save me $100 (for a new cover) I am all for it!  :clapping:
