Author Topic: trans and rearend  (Read 1597 times)
Offline Lovemy440
  • mopar or no car
trans and rearend
« on: August 20, 2004 - 06:00:34 PM »
trying to find what the highest hp trans and rearend that is still streetable is  anyone know of any??
Nos is neat,
Injection hard to beat
But when it"s time to get goin
I'd rather be blown
Offline torredcuda
  • Epping NH joined 11/23/03
Re: trans and rearend
« Reply #1 on: August 20, 2004 - 07:01:16 PM »
If you mean a trans and rear that can handle the most hp it`s all up to the parts used and the person biulding them.There are 727s and 904s behind some pretty stout engines and for rears the Dana and Ford 9" are very strong.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Lovemy440
  • mopar or no car
« Reply #2 on: August 20, 2004 - 09:26:15 PM »
well iam building  a twin turbo 440
and trying to find what transmission and drivetrain tha can handle 1500 ot 2000 hp and still be drivable
is this possible??
Nos is neat,
I'd rather be blown
Offline Carlwalski
« Reply #3 on: August 20, 2004 - 11:33:09 PM »
HOLY SH1TTTT!!!!!  :D ;D Your going to die in that car LMAO!!!! j/k
I'd either use a TF-727 or don't get angry lads but a Powerglide is also a great option, only one shift needed and then just hang on for your life LOL!!!  ;D 8) You could always get a custom made trans, tell them what you plan on doing and they'll sought something out.  ;)
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #4 on: August 21, 2004 - 04:55:35 AM »
Lenco & Jerico Trannys are designed for extreme HP , do not use the 727 it will come apart with that kind of power , There are Sheet Metal diffs available , the Dana is also very strong , Mark williams & Strange have some high HP options availabe
RedLine
« Reply #5 on: August 21, 2004 - 07:34:44 AM »
Also, a local buddy into pro stock racing.    Modifies 727's with lighweight aluminum parts.
Figure the horsepower that delivers 6 sec / 200 mph.    see http://www.sheltonracing.net/PartsStore_transmiss_main.htm
« Last Edit: August 21, 2004 - 07:59:08 AM by RedLine »
« Reply #6 on: August 21, 2004 - 12:40:52 PM »
I saw a blown Cuda in the 9 second range launch the drum over the grandstands into the pit area , he may have beem close to 1000 HP , it was a 727 he was using
Offline Carlwalski
« Reply #7 on: August 21, 2004 - 05:28:00 PM »
But then again there are TF-727's in lower bracket racers that have held up fine. Isn't it just a bit of luck also?  ???
I've heard the PowerGlide is one awesome transmission.  :D
