A leaking wheel cylinder will cause the brakes to grab. Also, a lot of brake dust caught inside the drums will cause that problem too. Humid weather doesn't help the situation either. I'd just pull the drums and clean everything out. Then you will be able to see if a wheel cylinder is leaking.
