Author Topic: Amp Meter Pegged when Running  (Read 8879 times)
Re: Amp Meter Pegged when Running
« Reply #30 on: April 13, 2010 - 05:13:29 PM »
Try running a wire direct from the battery to the alternator and recheck charge rate at the battery.
This does not solve the problem of the alt. overcharging but is a good idea to keep the car from burning to the ground, don't forget a fusible link ... Best Of Luck cwestra
Offline cwestra
« Reply #31 on: April 13, 2010 - 08:43:33 PM »
Well, I found the source of the problem tonight.  It turns out it was the alternator.  Fortunately, I had the old one lying around to make comparisons against.  I actually installed it a couple of days ago in hopes that it might work but since it had the same symptoms I dismissed it as a possible source.  But tonight I took both of them apart and saw the difference.  The old one has 2 insulated field connections, each with brushes that contact the armature.  The new one, however, has just 1 field and a ground connection, with brushes attached to each.  I had my 2 fields connecting to the field and the ground with it grounding to the case.  I can't understand why they would configure an alternator this way (grounding one of the brushes), but that is clearly what it is set up to do.  I should have noticed the "GRD" stamped on the case next to it, I suppose.  Any insight as to what this alternator goes on would be appreciated, as would any recommendations on how I could possibly salvage this alternator.
Corey - in Northern Indiana
Offline cwestra
« Reply #32 on: April 13, 2010 - 08:46:50 PM »
Sounds like the feild wire is shorted to ground, full feilding the alt. disconnect at reg. and at alt and ohm to ground.
You called it correctly.
« Reply #33 on: April 14, 2010 - 04:21:58 AM »
in 69 the regulator switched the power to the field in the alternator & the second brush was grounded
in 70 they switched the ground through the regulator so the ground is isolated
