Author Topic: Fuel Bowl Holley - Inlet Thread Stripped  (Read 3161 times)
Offline cwestra
« on: October 21, 2009 - 11:46:00 AM »
The inlet threads are stripped in the center carb on my 6-Pak set-up.  I assume there are no fixes for this.  Can I buy a bowl for it though?
Corey - in Northern Indiana
Re: Fuel Bowl Holley - Inlet Thread Stripped
« Reply #1 on: October 21, 2009 - 01:02:31 PM »
Holley will sell the bowls seperatly but will not ship to Canaduh  :banghead:
 & yes you do need to replace it unforrtunatly
Offline moper
« Reply #2 on: October 21, 2009 - 01:08:15 PM »
CP... do you know which carb has the same bowl? The 4bbl ones? I dont recall which ones work. I have a few you can have but the are not 6bbl... so the vent setup is wrong. I swear there was some 600CFM 4bbl that used the exact same centerhung bowl with the vent and vapor nipple...
« Reply #3 on: October 21, 2009 - 01:16:03 PM »
I believe you are correct on the center carb Only , the outboard is totally unique
Offline moper
« Reply #5 on: October 21, 2009 - 01:28:31 PM »
CW if you cant find anything let me know. I can buy it and then ship to you. But last time I shipped to the great white north it took 3 weeks to clear the border.
« Reply #6 on: October 21, 2009 - 01:50:43 PM »
I believe Cwestra is in the US so he should have no issue getting one
Me on the other hand  :banghead:
Offline cwestra
« Reply #7 on: October 21, 2009 - 01:54:51 PM »
Here's a couple of pictures of the bowl, moper.  I'm certainly interested in what it would cost me through you.  I have not done any checking, as I was not sure where to look or what the part number even was.  I'm located in Indiana.  Let me know what you think.  Much appreciated.
Offline cwestra
Offline cwestra
« Reply #9 on: October 21, 2009 - 04:13:12 PM »
I can get one for $45 plus shipping, moper.  Would your price be any better?  Thanks.
Offline moper
« Reply #10 on: October 22, 2009 - 09:15:27 AM »
I was trying to get around the "shipping to canada" Deal. I cant buy things any cheaper than you could....lol.
Offline Moparal
« Reply #11 on: October 22, 2009 - 05:38:11 PM »
If you're not running that vent to the valve cover breather, then a regular bowel will work. I guess you know that tho
Offline cwestra
« Reply #12 on: October 22, 2009 - 06:53:16 PM »
I will be using the vent.  I thought it went to the air cleaner though.  I ended up going with the eBay lead you provided.  The other ones did not have the "Holley" cast in and the vent tube was not there.  I called Holley and they said they could make one but that it could take up to 2 weeks.  I needed one ASAP.  Thanks again for the lead.  It turned out to be extremely helpful.
