Brake problem
Author Topic: Brake problem  (Read 563 times)
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
Brake problem
« on: October 22, 2009 - 11:53:24 AM »
70 RT/SE Challanger disc/drum setup. I have changed drums, shoes, wheelcylinders and lines and it still brake like nada on the passengerside. So after have changed lines all the way there is just the Proportioning Valve left. Should it be 2 valves or just one original? There is two now.
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
Re: Brake problem
« Reply #1 on: October 22, 2009 - 12:05:12 PM »
the  70 Challenger had the double valve with disc brakes , you can replace it with a later single valve type from a 5th ave or volare etc but you woulkd have to modify the lines to make it work
Offline ESGEE
    • SG´s site
Re: Brake problem
« Reply #2 on: October 22, 2009 - 12:16:08 PM »
Thanks for the info :cheers:
70 Charger 500
Re: Brake problem
« Reply #3 on: October 22, 2009 - 02:30:45 PM »
 :2thumbs:
