Conv winshieldframe trim
Author Topic: Conv winshieldframe trim  (Read 904 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
« on: October 22, 2009 - 12:53:36 PM »
How does the chromemoldings around the windshield frame on my convertible goes off except for the visible screws? Not the windshield moldings.
Per
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Re: Conv winshieldframe trim
« Reply #1 on: October 23, 2009 - 03:52:30 PM »
This would be the ones I mean.
Per
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #2 on: October 23, 2009 - 08:15:14 PM »
If I remember correctly it should lift or twist off carefully. Start by removing the interior trim around the windshield that will give you a little more wiggle room. There is some sealer or glue under it probably from the windshield or its factory sealant to stop water.
Sides firsst then the top 2 sections.  :cheers:
Go Fast & Have Fun...
Offline JayBee
« Reply #3 on: October 24, 2009 - 08:10:39 AM »
Per, dodgeboys is right, there is some sticky stuff under it. Be very careful , I ended up putting a crease in mine in that narrower and weaker area by the notch for the top's pin. Good Luck, hope you don't do what I did.
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #4 on: October 25, 2009 - 02:38:35 PM »
Was a lot of sticky s**t there. I lost one A-pillar molding because I didn't see it was a screw attached to it at the bottom. :banghead:
Per
Offline JayBee
« Reply #5 on: October 25, 2009 - 05:57:43 PM »
If the molding in the picture is what you lost, don't worry too much, they can be found easier than the stainless steel stuff. And FYI, I found some moldings and discovered that the screw hole is drilled in different spots and they had the same part number. Some have it lower and some have it higher up. Also, I believe you can use one from a hard top and just have to cut the top part of it off.
John
2014 Toyota Avalon
« Reply #6 on: October 26, 2009 - 01:58:42 PM »
John, unluckely it was the outer chromemolding I managed to destroy. :banghead: Any chance they
will be repoped?
Per
    • THE DODGE BOYS
« Reply #7 on: October 26, 2009 - 07:46:57 PM »
will be repoped?
Per
 :22yikes: :22yikes: :22yikes: :22yikes: :22yikes: :22yikes: :22yikes: :22yikes:
Thats not pretty  :faint:
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
« Reply #8 on: October 26, 2009 - 08:26:38 PM »
We can fix that!!
