Author Topic: Firewall metal  (Read 1592 times)
Offline coupman35
  • It going to be FUN
Firewall metal
« on: October 22, 2009 - 04:49:28 PM »
Hi I have a fire wall that am parting out let me no what you like and will work out a deal also have a right side hood hing,and a set of rocker trims if you like more pic email me a rpoitras@ntl.sympatico.ca
1941 Dodge truck 340cu
1935 ford 3window coupe 327cu
1965 Acadian Beaumont Convertible 283cu
1973 Challenger 318cu
Re: Firewall metal
« Reply #1 on: October 22, 2009 - 04:57:21 PM »
Is that off of your car?  If so, your numbers to the vin Id looks like is still on it. You may want to take that off and save.
Offline coupman35
Re: Firewall metal
« Reply #2 on: October 22, 2009 - 05:12:32 PM »
No this is a clip that i pick up for parts ,i dont see any number on it.
Re: Firewall metal
« Reply #3 on: October 22, 2009 - 05:14:54 PM »
ok, just tryin to look after ya is all. Drivers side by the wiper cowel hole. Like 5 or 6 numbers is what I was referring to
Offline coupman35
Re: Firewall metal
« Reply #4 on: October 22, 2009 - 05:22:56 PM »
Thanks
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
Re: Firewall metal
« Reply #5 on: October 26, 2009 - 01:33:15 PM »
Hello! How is the pass side area that the heater unit goes into for fresh air? I need the area surrounding the raised square.
Thanks
Robert
Offline coupman35
Re: Firewall metal
« Reply #6 on: October 26, 2009 - 02:02:32 PM »
The duck  is rusted on one side
Re: Firewall metal
« Reply #7 on: October 26, 2009 - 02:10:03 PM »
How is the area about 5 inches around the opening?
Offline coupman35
Re: Firewall metal
« Reply #8 on: October 26, 2009 - 02:16:14 PM »
It is good very solied only surface rust
Re: Firewall metal
« Reply #9 on: October 26, 2009 - 03:53:12 PM »
How much for the section?
Thanks,
Robert
Re: Firewall metal
« Reply #10 on: October 26, 2009 - 09:01:10 PM »
Hello! I drew a green line covering the area I need. The dotted line means the area underneath the top part of the cowl. Let me know if this is what you were thinking about for the $30.00. Also, I live in Illinois. Not sure how much shipping would be from Canada.
Offline 74chall
  • Mopar or No Car
Re: Firewall metal
« Reply #11 on: November 15, 2009 - 05:05:49 PM »
still have? i could use a couple of hunks off it!  :working:
Offline coupman35
Re: Firewall metal
« Reply #12 on: November 15, 2009 - 05:37:23 PM »
Yep still have it i just got ot out of the garage today what do you need .
Offline 74chall
  • Mopar or No Car
Re: Firewall metal
« Reply #13 on: November 15, 2009 - 06:40:58 PM »
Ok i need the section which i drew a box around. I just wanted to make sure the section that i put an oval around is not rot?   I also need the section to the far right which i put an arrow pointing to, its right above the section which was cut out.
Offline 74chall
  • Mopar or No Car
Re: Firewall metal
« Reply #14 on: November 15, 2009 - 06:49:28 PM »
Heres what im working with. You can get the idea of what parts i need. Would be great if you could over cut the sections,the i can cut out the section on the flattest points and butt weld it in.
Price shipped to 08050 Nj. thanks so much! Nick
