Author Topic: Radiator Shroud  (Read 500 times)
Offline BadJoey
Radiator Shroud
« on: October 22, 2009 - 08:02:51 PM »
I'm looking for a 26 inch radiator shroud for a 70 challenger . The motor is a 440 . I bought a after market one in the spring and it was close . Thought I could make it work . WRONG . 100 plus dollars poorer and 6 months later here I go again .  :pullinghair:
Re: Radiator Shroud
« Reply #1 on: October 22, 2009 - 09:17:37 PM »
What went wrong?  The shrouds last numbers say 26 on it?  Is your fan a 18.5 inch fan?
Offline BadJoey
Re: Radiator Shroud
« Reply #2 on: October 23, 2009 - 02:11:06 PM »
I do not think the shroud was even for a Challenger . One of the 4 bolt holes wasn't even close to lining up . I made a bracket which worked for a while but with time things moved and the fan would start hitting . I'd adjust things and that would work for a while and this kept going on :banghead: till the shroud now looks like crap and I can no longer stand it . Lesson learned if the part don't fit right out of the box I'm sending it back .
Offline pink panther
Re: Radiator Shroud
« Reply #3 on: October 23, 2009 - 02:17:46 PM »
I bought mine from Mancinnis
Re: Radiator Shroud
« Reply #4 on: October 23, 2009 - 03:03:23 PM »
Dave can fix you up with a MP re-issue for well under $100.   Email him, c-c members get a discount
http://www.rosevillemoparts.com/product_info.php/p/shroud-26-inch-70-73-b-rb-hemi-b-e-body/products_id/300
Offline BadJoey
Re: Radiator Shroud
« Reply #5 on: October 23, 2009 - 07:59:48 PM »
THANK YOU GUYS . This site keeps coming through and through you're the best . :cooldancing:
