Author Topic: Wider front track  (Read 1123 times)
Offline the_engineers
Wider front track
« on: October 23, 2009 - 05:57:52 PM »
Just a thought...can C body UCA and LCA's be used to widen the front track on an E body?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Re: Wider front track
« Reply #1 on: October 23, 2009 - 06:37:27 PM »
maybe , I think the upper arms are physically wider betweent he bushings & the lower definatly uses a larger pivot pin so the K frame would need to be modified
« Reply #2 on: October 23, 2009 - 09:36:59 PM »
Is there a way to do this wth E-Body specific parts?
Brooks
1971 'Cuda 360
Offline autoxcuda
    • Spring Fling
« Reply #3 on: October 23, 2009 - 10:42:48 PM »
Not really.
But the quesiton is why?? E-bodies are proably the widest of all ponycars when comparing thier track width to wheelbases. And if you made them wider you'd have to flare the fenders. Try cramming 275/40/17 tires in the front of one and see if you want the track any wider. It's tough enough allready.
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
« Reply #4 on: October 23, 2009 - 10:50:35 PM »
Don't those tram badly?
Brooks
1971 'Cuda 360
« Reply #5 on: October 24, 2009 - 12:15:02 AM »
No worse than any other later model ride like a Viper or Vette.
A body lowers control arms are  longer than B/E arms. I think by 1/2" per side if I recall correctly. However, you would need to have custom uppers, or really long threaded heim joints, to get the camber back in a reasonable range.
Offline autoxcuda
    • Spring Fling
« Reply #6 on: October 24, 2009 - 12:55:20 PM »
True, the A-bodies are wider and you'd need the upper moved out to. Wouldn't be a bad idea to run an rod ended strut rod because the LCA would be moved out slightly.
But still the question is why do you want the wider track??
I think I saw a thread on ProTouring.com or something that was talking about long UCA and LCA's. A theoretical discusson, but not practical.
Spring Fling XXX
April 22 & 23 2016
« Reply #7 on: October 24, 2009 - 04:31:27 PM »
Well, it would allow a different offset on the wheels which could alter scrub radius a slight amount. But yes, not sure about the practical aspect of it.
