Author Topic: Eddy Performer RPM Intake Height Issue ????  (Read 3986 times)
Offline outlawse
« on: October 23, 2009 - 10:03:51 PM »
Guys,
Will a Eddy Performer RPM dual plane intake for my 440 fit under my stock Ralley Hood?
Or is it too tall and require a cowl hood ?
Thanks....
John
outlawse@aol.com
1972 Dodge Challenger
1970 446 RB: Six-Pack cam, M1 Dual plane Intake, Hooker Headers, much more...
Turbo Action 727: 3400 Stall, Manual Cheetah Valve Body - 3.91 Gears
On bench:  Performer RPM Intake, 509 114 LSA Cam, 440 Source Heads
Offline the_engineers
Re: Eddy Performer RPM Intake Height Issue ????
« Reply #1 on: October 23, 2009 - 10:09:14 PM »
What air cleaner are you running?  Drop base, and if so, how deep?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline dwbiggs
« Reply #2 on: October 25, 2009 - 01:22:10 PM »
I use RPM intake with Holley and a drop base with 3" element worked.  I also used the K&N filter top.  I think the drop base was something like 1 5/8".
« Last Edit: October 25, 2009 - 01:25:35 PM by dwbiggs »
Offline mojavered
  • Someday!
« Reply #3 on: October 29, 2009 - 01:59:02 PM »
Does that 750 give you enough carb?
Jason
Offline rusty dodge
  • 74 challenger 440-727-3:55
« Reply #4 on: October 29, 2009 - 02:11:18 PM »
My 800 AVS and a .250" thick gasket using a drop base air cleaner just barely fit. I have to screw the lid down very tight, or it will rub. Also, the bottom of the drop base will not clear the electric choke housing on the AVS carb. You will need to dimple the air cleaner base to clear that. If you use a holley, this is not an issue.
Offline outlawse
« Reply #5 on: November 02, 2009 - 05:57:01 AM »
Thanks for the answers.
Tonight will be the first test drive.  Should be fun...
Offline mojavered
  • Someday!
« Reply #6 on: November 02, 2009 - 09:08:25 AM »
Welcome to the site!  Enjoy your drive and post some pics!
Jason
Offline outlawse
« Reply #7 on: June 08, 2010 - 12:36:39 PM »
I have the Mopar Performance black air filter.
http://www.summitracing.com/parts/DCC-5249807/RepairParts/?prefilter=1
Will this work with the Performer RPM ????
I am ready to order now....
Offline mopar12372
    • mopartech
« Reply #8 on: June 08, 2010 - 09:04:17 PM »
yes , why would you get that ? are you on a budget ? that set up that ( dwbiggs ) has is the best setup to use for a p erformance application and looks. it all comes to what you want to do and what you like as in looks and performance.
RESTO PICTURES
Offline Aracer
« Reply #9 on: June 08, 2010 - 11:05:45 PM »
Moroso drop base, on a Holley, will fit under a flat barracuda hood, with RPM on a 440.
Offline outlawse
« Reply #10 on: June 09, 2010 - 07:35:08 AM »
I had a new MP Air filter on the shelf.  Plus it matches my valve covers.
I do like the top flow lid, but I minus well use the new MP setup for now.
So basically just a drop base for the bulge hood.
Offline outlawse
« Reply #11 on: June 09, 2010 - 07:48:29 AM »
Well it seems nobody carries a drop base for 12.75 sized air filters like the Mopar.
So........... I guess I need to take a look at the Holley Street intake.
Offline dwbiggs
« Reply #12 on: June 09, 2010 - 04:31:34 PM »
Quote
Probably not the best for the track but its nice and responsive and I haven't run into any noticable flat spots or anything like that on the street.  I would like to try a chokeless Proform or Quick fuel carb for fun  :burnout:
