Author Topic: Steering wheel play  (Read 878 times)
Offline IndyCuda
Steering wheel play
« on: October 25, 2009 - 10:25:47 PM »
I just purchased a '72 Barracuda with power steering.  :bananasmi It has a Grant steering wheel. I know the front end needs rebuilt but There is still a whole lot of play in the wheel, even when the engine is shut off. Is there a bearing or something in the column that I can replace or something to tighten to take it out? I have to put a new ignition lock in anyways and want to take care of this while I have it apart.
Re: Steering wheel play
« Reply #1 on: October 26, 2009 - 12:18:56 AM »
MOst likely it is in the coupler with the shoes in incorrectly or wear or the steering box , I doubt it has anything to do with the column
Offline dodge freak 2
« Reply #2 on: October 26, 2009 - 01:34:47 AM »
Anybody have a picture-info on how to correctly place the shoes in the coupler. I replaced my box 2 years ago with a new coupler and the shoe kit but there is play in the coupler...the shoe kit isn't much, I should redo it soon. (I thought those couplers just had play in them)
« Reply #3 on: October 26, 2009 - 01:42:15 AM »
The spring that holds the shoes in place locates with the loop on the spring to one side of the column not under the end of the column , this will locate it correctly  , if you sit the shoe into the coupler you can clearly see that it is too narrow sitting one way in the coupler
Offline IndyCuda
« Reply #4 on: October 26, 2009 - 04:21:26 AM »
Thanks, I will give it a whirl.
« Reply #5 on: October 26, 2009 - 08:42:04 AM »
Good how to..... Getting the big roll pin out is the 1st step
http://www.buschis-place.de/steeringcouplerrepair.htm
