Front arm bushings
Author Topic: Front arm bushings  (Read 2290 times)
Offline tomsa
    • My cars in swedish
Front arm bushings
« on: October 26, 2009 - 11:39:14 AM »
How to replace   lower front arm bushings?
Are the bushing pressed in from the front of vehicle and then the shaft inside?
Which direction shall I press it out?
like in the pic or the other way?
Re: Front arm bushings
« Reply #1 on: October 26, 2009 - 12:08:15 PM »
Press the shaft out the same way your arrow is pointed.  That is the same way the outer bushing sleave comes out as well.  You only have to remove the outer bushing sleave if you are replacing it with a factory rubber style bushing.  If you are installing a Poly bushing, the origonal outer sleave stays inside the LCA.
« Reply #2 on: October 26, 2009 - 12:13:06 PM »
the Muscle cars suspension kit has a puller to remove the pin fron the bushing then the rubber can be pryed out , I have also used a pickle fork & propane torch to heat it up enough to pry the pin out
 as said above the steel shell of the bushing is left in place for Poly bushinmgs assuming it is in good condition
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« Reply #3 on: October 26, 2009 - 12:14:15 PM »
 :iagree: If you are replacing it with a rubber bushing you need to get the outer sleave out. You will need this tool. I used it and it sure does make the job easy.
http://americanmuscle.carshopinc.com/product_info.php/products_id/89937/23501
Dave :wave:
Worlds first e-body trailer.    Severna Park, Maryland
Offline tomsa
« Reply #4 on: October 26, 2009 - 01:08:23 PM »
Thanks for quick answers :ylsuper:
I´ll try tomorrow
Offline tomsa
« Reply #5 on: October 26, 2009 - 06:48:50 PM »
I have already bought this kit from summit http://www.summitracing.com/parts/ENS-5-3112G/ but can anyone tell me what the 2 black items are ?
The other 4 is for upper control arm if I´m not wrong but where shall I place the other  ???
Offline Changin Gears
« Reply #6 on: October 26, 2009 - 07:38:19 PM »
Those are the lower control arm bushings.  You use those with the original inner and outer sleeves.
« Reply #7 on: October 26, 2009 - 07:43:19 PM »
The poly bushings don't use an inner sleeve do they?   Just the origonal outer sleeve.
Offline tomsa
« Reply #8 on: October 26, 2009 - 07:43:35 PM »
They seems so small compared the ones sitting there now but I will measure them tomorrow or in the morning is more correct
Sweden time is 40 minutes after midnight
I never learn if that is 0.40 pm or am    :clueless: I´m sorry :dunno:
Offline tomsa
« Reply #9 on: October 26, 2009 - 07:48:46 PM »
So I just remove the rubber inside
Is that how it´s done  for this type of bushing?
Offline purple1
« Reply #10 on: October 26, 2009 - 07:59:26 PM »
Yes. For the Poly bushings leave the outer sleave in place. How are the pins? Theads in good shape? I put new pins in when I installed mine. I think the Poly bushings used a different pin.
Dave :wave:
Offline tomsa
« Reply #11 on: October 26, 2009 - 08:03:24 PM »
The pins are fine
So u think I can´t use these pins with these bussings then  :crying:
I check when I have pressed them out
Where can I buy them or should I use stock bussings instead?
found them at mancini
http://chucker54.stores.yahoo.net/coarmst.html
and yes it seems to be 2 different types
order new bushings or order new pin  :clueless:
« Last Edit: October 26, 2009 - 08:13:02 PM by tomsa »
Offline purple1
« Reply #12 on: October 26, 2009 - 08:12:15 PM »
Offline tomsa
« Reply #13 on: October 26, 2009 - 08:14:56 PM »
listings for each type...
poly
http://chucker54.stores.yahoo.net/bebolocoarmp.html
Rubber
http://chucker54.stores.yahoo.net/bebolocoarmp1.html
Dave :wave:
 :ylsuper:
hehe I just found them and added them to my last post  :grinno:
But the qyestion is how to do now
order stock bussings or order new pin
Offline purple1
« Reply #14 on: October 26, 2009 - 08:23:11 PM »
I put a full poly-graphite kit from PST in mine, all but the lower control arm bushings are poly. The lowers are rubber. Someone here recomended not using poly for the lower bushings. I'm not sure why not. But I went with that recommendation and used rubber.
Dave :wave:
« Last Edit: October 26, 2009 - 08:28:22 PM by purple1 »
