Author Topic: MANUAL STEERING TO POWER STEERING ON 72 CUDA.  (Read 3206 times)
Offline 383DART
« on: October 26, 2009 - 12:13:31 PM »
I HAVE A 72 CUDA NO P/S.  I WANT TO PUT A P/S BOX IN IT. WILL THE SPLINE ON THE STEERING COLUMN SHAFT MATCH UP WITH SPLINE ON THE NEW POWER STEERING BOX. THANK'S.
Offline the_engineers
Re: MANUAL STEERING TO POWER STEERING ON 72 CUDA.
« Reply #1 on: October 26, 2009 - 12:16:10 PM »
Nope, spline is different.  Shouldn't be a problem to find a column, though.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #2 on: October 26, 2009 - 06:53:12 PM »
I think the length between power, and non-power steering column shafts is different too.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #3 on: October 26, 2009 - 07:12:54 PM »
The power steering column shaft is a couple inches shorter than the one on a manual column.
1996 Dodge Viper GTS Coupe
« Reply #4 on: October 26, 2009 - 07:17:00 PM »
Thanks.   :2thumbs:
  This just proves I have learned a thing or two from you other guys over the years.   :grinyes:
Offline moparrick
« Reply #5 on: October 26, 2009 - 07:36:53 PM »
I made this conversion on my 70 cuda years ago.  You will need a shorter column as the power box is much larger.  You should be able to find a PS column.  In my case, I found a box off of a 71 cuda, the pump came off of a 73 charger (same as 70 cuda pump).  Becareful with the pittman arm.  There are two different sizes and I am doing this from memory - The 70/71 pittman arm will not fit the 72 & newer box.  Make sure you get the brackets with your pump.  The complete project took me about 3 hours for the conversion.  The only speciality tool is the ball oint cracker wich you can get anywhere.
Good luck
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #6 on: October 29, 2009 - 11:05:34 AM »
Check ebag, there are several people rebuilding them, you can get a mint rebuilt/restored power steering column for around $250 to $350 depending on the vendor.  :2cents:
Offline 71cudajoe
    • 71 Cuda Restoration Project
« Reply #7 on: October 29, 2009 - 01:50:34 PM »
Good luck
You are right about the pitman arm. I swapped out a manual steering box on my Cuda with a PS unit from a slightly newer Mopar. I had to purchase a different pitman arm and a new, shorter steering column.
David - '71 HEMI Cuda Retro-mod
FOR PICS VISIT www.71cuda.net
« Reply #8 on: October 29, 2009 - 03:05:23 PM »
You know you can slide the shaft on your column and it will fit the power steering, then heat the plastic back up . It is a slide inner shaft
