Vin tag swapping
Author Topic: Vin tag swapping  (Read 4191 times)
Offline Paul_G
Vin tag swapping
« on: October 27, 2009 - 10:43:11 PM »
Is there any way a person can tell if the VIN tag has been swapped on a car? Any way to check other numbers or something?
Offline Bluemonster71RT
Re: Vin tag swapping
« Reply #1 on: October 27, 2009 - 10:46:35 PM »
Well I guess if you can find the build sheet that would help.  Then I suppose if you know the options on the car vs. what the tag shows as correct or incorrect for the year.
There are a few guys here that could help you alot more than that.
1971 Challenger RT 383 4spd
Alaskan_TA
« Reply #2 on: October 27, 2009 - 10:51:24 PM »
Comparing the VIN to the body stampings (1969 model year & newer) would be the first thing to do.
Offline Paul_G
« Reply #3 on: October 27, 2009 - 11:09:11 PM »
Where would I locate the body stampings?
Alaskan_TA
« Reply #4 on: October 27, 2009 - 11:19:15 PM »
It depends, what kind of car? What model year?
Offline Paul_G
« Reply #5 on: October 27, 2009 - 11:34:20 PM »
70 to 74 E body mainly, but I have my eye on a 74 that is local to me. The VIN tag on this 74 has normal looking rivets. Others I have seen have a kind of pantastar looking rivet.
Alaskan_TA
« Reply #6 on: October 27, 2009 - 11:57:55 PM »
If original, it should have rosette rivets.
Check the top of the cowl on the driver's side & the radiator support on the top or engine side, the stamp there is normally within 20 inches or so of the battery.
Offline 73Chally
« Reply #7 on: October 28, 2009 - 07:22:40 AM »
It's a good chance the VIN is correct, but that the dash was replaced at some point.  The correct rivets are not widely available, so they might have just grabbed a couple off the shelf to put the tag back on.  Ask the owner if it's the original dash.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #8 on: October 28, 2009 - 07:35:05 AM »
 :iagree: Or if its been recovered and they didnt save them.
Go Fast & Have Fun...
Offline Katfish
  • 70 Challenger
« Reply #9 on: October 28, 2009 - 10:37:31 AM »
That would be my 1st guess.  I did that exact same thing on my 1st Challenger.  Picked up a nice used dash from the junk yard.  Put the VIN on with standard rivets.  Didn't know any better back then.
Offline myhorsepower.com
« Reply #10 on: November 23, 2009 - 10:00:18 AM »
Check this out ...You could change the core support and the cowl the dash and door. oh almost forgot the fender tag. Now how do you tell???  Maybe the 7 1/4  rear under a V-8 car (318)  It's a 71 Barracuda (318) maybe???
Offline Moparinho
  • "Too many Ferrari and Lambo around me..."
« Reply #11 on: December 02, 2009 - 09:31:11 AM »
is it correct that I've only the last VIN digits in the cowls stamping ?
Paolo (Italy):
'70 Challenger R/T 383 Hemi Orange
'70 Barracuda GC convertible 383  (coming soon...)
'65 Shelby Cobra 427 Replica
Offline Cuda Cody
  • Vancouver, WA
« Reply #12 on: December 02, 2009 - 12:36:27 PM »
Yes, that is correct.  The full VIN is shown on door mylar and the dash, but on the cowl and radiator support only have the last 6 numbers with with the year and plant letter codes.
If you post some pictures of the VIN # your have found on your car I'm sure everyone would be more than happy to help you.
 :scared:
