How to remover upper ball joint
Author Topic: How to remover upper ball joint  (Read 6240 times)
Re: How to remover upper ball joint
« Reply #15 on: October 31, 2009 - 02:09:16 PM »
Thanks  :worshippy
I let you know how it turns out
You also can visit my web site to see pics
It´s in swedish so far but I will try to translat it to english when I have the time,but a pic says more then 1000 words I have heard ;)
Is that swedish words or english words.   :cheers:    100 english words = 10 swedish       :blah:   goodluck
Offline tomsa
    • My cars in swedish
« Reply #16 on: November 03, 2009 - 10:15:14 AM »
Next question
Tried to remove the bushings in UCA and so for I just got one out
But is this the outing part of the bushing that alsa hace to be removed?
The new bushing is about 3/16" bigger then the hole in UCA so I guess it´s like that but I cant see any gap that indicates that there are 2 different pieces  ???
« Reply #17 on: November 03, 2009 - 10:54:53 AM »
Quote
I thought the exact same thing.  It didn't look like there was a gap between the outer bushing shell and the UCA but there is.  I have a cheap press that I used along with an old socket to remove and install the bushings.  The old ones will press out from the inside.
Here's a pic of mine with the bushings removed.  This pic should help you see how it comes apart.
« Last Edit: November 03, 2009 - 11:03:48 AM by burdar »
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« Reply #18 on: November 03, 2009 - 11:30:56 AM »
Next question
Looks like you found one with that extra ring installed on the inside of the bushing. This has been a topic before, they were added at the factory when the upper bushings did not press in tight enough. Makes it a little harder to remove that bushing.
Dave :wave:
Worlds first e-body trailer.    Severna Park, Maryland
Offline tomsa
« Reply #19 on: November 03, 2009 - 11:57:50 AM »
Thanks  :thumbsup:
Yeas it look lake the one with the extra ring
But burdar
your uca does´n look like mine on the inside
Is there a new and old version?
Mine is a 1970 car and I have to press my bushing from inside to outside to get them out
« Reply #20 on: November 03, 2009 - 12:01:27 PM »
Yes, you have to press them from the inside to the outside to get them out.  The arms are the same.  You just have an extra ring on the inside witch was explained in the post above.
Are those extra rings available new anywhere?  I had one bushing press in real easily.
« Last Edit: November 03, 2009 - 12:07:06 PM by burdar »
Offline purple1
« Reply #21 on: November 03, 2009 - 12:27:00 PM »
I have never seen them available new. I had no idea the factory even did that till I found one installed on my control arm. Maybe someone else with more info will chime in here.
Dave :wave:
Offline tomsa
« Reply #22 on: November 03, 2009 - 12:43:15 PM »
Dave :wave:
The arms look different on the pics
mine has a "sleeve" (is that the correct word?) on the inside ánd on the outside and it don´t looks so on on burdars pic
Offline purple1
« Reply #23 on: November 03, 2009 - 12:46:30 PM »
I think it is just the angle of that pic. Your arms should look just like that once you get the bushings out.
Dave :wave:
Offline tomsa
« Reply #24 on: November 03, 2009 - 12:50:31 PM »
Dave :wave:
Ok so it´s one sleeve or what its called om each side then
Like a tube that goed through the uca and are ~3/4" on the inside and 1/2" on the outside?
Offline purple1
« Reply #25 on: November 03, 2009 - 12:55:11 PM »
Yes. Once you get those outer shells out of the arms they should look just like that pic burdar posted.
Dave :wave:
Offline tomsa
« Reply #26 on: November 03, 2009 - 12:55:35 PM »
Or shall I take away the both of the "tubes" inside so nothing  support the busch there?
Looks that there in no "inside tubing" on new uca from mancini
I have 2 diam on the inside as u can see on my pic
Offline purple1
« Reply #27 on: November 03, 2009 - 01:05:12 PM »
The outer "tube" is part of the control arm. I only have this one pic showing the new bushings installed in the arms. Mine pressed in just fine and did not need that extra inner ring (tube) re-installed.
Dave :wave:
Offline Kapteenikosmos
« Reply #28 on: November 03, 2009 - 01:21:45 PM »
The sleeve you have on the inside of the arm looks like it functions about the same as the bearing retainer collar on the rear axles. If the bushing has been sloppy on the original hole on the upper control arm, they have pressed a retainer sleeve over the bushing so that the bushing itself wont fall off. In your pic, it looks like you have removed the internals of the original bushing and the outer shell of the bushing is still in place, like the collar is holding it there?
I removed all four bushings last weekend from mine and I had some major problems with the last one. First three came out without any problems but on the last one the "face plate" on the inside side of the bushing went inside the outer shell and kinda ballooned and stretched the end so that there was no way it could have been pressed out completely, I got it about 2/3 way out before it stopped. I had to cut the other end off the bushing off and press it out to the other direction.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline tomsa
« Reply #29 on: November 03, 2009 - 02:32:15 PM »
2 of my problems is that I don´t have a press and no large socket that fits over the bushing at the moment
Anyway now I got one bushing and x-tra ring away
Both arms has one side with a extra ring and one without
Here the rest of bushing/ring
« Last Edit: November 03, 2009 - 02:34:40 PM by tomsa »
