Author Topic: steering wheel retaining nut  (Read 645 times)
Offline IndyCuda
« on: October 28, 2009 - 06:58:49 PM »
I am trying to rebuild my steering column on '72 baracuda w/o tilt. It needs a cam for the signal and a new ignition lock. I popped off the grant wheel ad grabbed an extension to remove the steering wheel retaining nut. The crush can will only allow me an 11/16 through the opening and it does not appear to be large enough. Is this a magic nut...?
Offline 4Cruizn
  • HEMI FISH
Re: steering wheel retaining nut
« Reply #1 on: October 28, 2009 - 07:02:33 PM »
Please post a picture as I'm confused.    :clueless:
Offline IndyCuda
« Reply #2 on: October 28, 2009 - 07:19:09 PM »
It is a grant wheel and an aluminum crush can with this piece welded over the top...they got it on somehow
« Reply #3 on: October 28, 2009 - 09:59:02 PM »
well it should take like a 7/8 socket.  They may have welded that piece on after install. You may need to cut the hole bigger off to the left side.   Push a rag through the hole, then use a die grinder
