Author Topic: Door Hinge ?  (Read 735 times)
Offline 67vertman
  • Member since 9-23-2005
Door Hinge ?
« on: October 28, 2009 - 08:46:20 PM »
Ok ?s
Has anyone replaced the "S" hook on a hinge before?  I have looked but can not find any info about replacing one. :clueless:
I need some quidance before I try it this weekend.  :grinyes:
Do you need to remove the hinge to replace the hook?r can it be done with the hinge on the car?
Any tricks, i should know about?
Thanks.
Offline dutch
Re: Door Hinge ?
« Reply #1 on: October 29, 2009 - 04:00:21 AM »
should work, but might need some Mc.gyver-ing...  you need to "over-tension" and push up the spring in order to get it out of its position.
*** Bart ***
Re: Door Hinge ?
« Reply #2 on: October 29, 2009 - 04:56:59 AM »
you can change the S spring without removing the hinge
Offline UKcuda
  • Tell them I'm on my way
Re: Door Hinge ?
« Reply #3 on: October 29, 2009 - 07:43:41 PM »
It's easy.  Use a long screwdriver to open the end of the spring away from where it locates to the hinge and then gently tap the spring vertically with a hammer.
Best to wear goggles just in case the spring fractures - I once had one do that when I was putting it on.
'72 'cuda
Offline 67vertman
Re: Door Hinge ?
« Reply #4 on: October 29, 2009 - 10:40:42 PM »
Thanks Guys.  I will be doing it this weekend.  I am glad to know it can be done without removing the hinge.
Offline 67vertman
Re: Door Hinge ?
« Reply #5 on: October 31, 2009 - 06:45:22 PM »
I got it in today....the "s" bar that is.  It went in pretty easy, and now the door works like it should.  :2thumbs:
