Author Topic: Redline Gauge Works Restored 72-74 Rallye Instrument Cluster XLNT! $850  (Read 1052 times)
Offline redlinegw
Here is a super clean fully restored 72-74 Dodge Challenger / Plymouth Barracuda rally instrument cluster. This cluster was restored by the experts at Redline Gauge Works so you know it was done right! www.redlinegaugeworks.com No stone unturned in this resto. All new artwork on the gauge faces "NO DECALS" all faces were sandblasted and painted, speedometer completely rebuilt and calibrated back to factory specs, odometers completely restored, tach converted to have all new modern internals "not a band aid circuit board like the other guys use" this tach will work with any aftermarket ignition system like MSD and is totally accurate throughout the entire range, clock has been converted to quartz internals for total accuracy, fuel, temp and oil psi gauge calibrated to factory specs with a new Solid State voltage regulator, ammeter serviced and a complete detail done on the cluster housing, pointers painted the correct color and plastic lens polished to look new! Ready to go with a 2 year warranty on everything. Give us a call if you have any questions at (661) 259-8891 ask for Shannon. This cluster will work perfectly on 70-71 cars as well however it is not correct, the resets for the clock and trip odometer are in different locations and the tach is 7k instead of 8k. Thanks for looking! This cluster is SOLD! SOLD! SOLD! Thanks.
« Last Edit: November 02, 2009 - 05:19:31 PM by redlinegw »
