Author Topic: Mad Electrical amp gauge bypass on '73 Cuda  (Read 3555 times)
Offline vpittman
« on: October 29, 2009 - 07:18:48 PM »
So I'm about to try the Mad Electrical amp gauge bypass the Saturday... (http://www.madelectrical.com/electricaltech/amp-gauges2.shtml). I just pulled the gauge cluster and the amp gauge is still conneted.
The wires on the firewall bulkhead are numbers 16 (battery) and 18 (Alternator), correct ?
Anything I should look out for ?
Thanks !
Re: Mad Electrical amp gauge bypass on '73 Cuda
« Reply #1 on: October 29, 2009 - 08:43:25 PM »
That's correct.
Offline 73EStroker
« Reply #2 on: October 29, 2009 - 10:18:13 PM »
You do not necessarily have to bypass the ampmeter. What I did was what that article shows, and that was to by pass the connections at the bulkhead connector with straight though new #10 wires but retained the ammeter. On the ammeter you simply have to ensure the nuts that hold the terminals in the guage itself are firmly tightened. Not too tight but they do come loose over the years. Mine were firmed up by taking the top nut and terminals off then tightening the bottom nut. Reinstall the ammeter wires and the top nuts. Works like a charm. I have the original 73 harness and all electrical circuits are working perfectly. All it takes is a thorough check over before reinstalling the harness.
Barry (Salmon Arm)
Offline Katfish
  • 70 Challenger
« Reply #3 on: October 29, 2009 - 10:37:50 PM »
Here's some good info also,  1 of the best things is to run a jumper straight from alternator to battery.  No more flickering lights.
http://www.allpar.com/history/mopar/electrical.html
