Author Topic: BIG problems - A-body K-Member..  (Read 1492 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: October 30, 2009 - 10:27:30 AM »
I'm into changeing my racecar into a streetcar..
I got a v8 K-member, but nothing to mount the engine to - use to go with an engine plate between block an wather pump housing....
We are in a 68 Cuda...
Is the V8 K-member the same for small or big block..???
Is there different engine mount plates, the part that goes on the block..???
Anyone got pics. of an original V8 K-member..???
Re: BIG problems - A-body K-Member..
« Reply #1 on: October 30, 2009 - 11:11:47 AM »
Schumaker has mounts to install the big block into a V8 A body K but you still need a new K frame
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #2 on: October 30, 2009 - 02:21:47 PM »
I got another K-Member I was thinking of use, but it don't seems to be the original way either..???
It comes from a cuda who has been droven with a 383cui...
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #3 on: October 30, 2009 - 05:21:08 PM »
Jeps, I have seen those before, but they will not fit my K-Member.. :clueless:
Offline mickey
« Reply #4 on: October 30, 2009 - 08:20:17 PM »
Did you have a spool mount or biscut mount, believe the spool was later year a-body.
« Reply #5 on: October 31, 2009 - 02:07:38 AM »
the 73& up K frame with the spool mount is often used to install a big block
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #6 on: November 01, 2009 - 03:19:15 AM »
Looks like my K-member is home made for -??  maybe B-body mounts..???
See pic. further up..
