Author Topic: 70 F383-HP  (Read 3073 times)
Offline js27
  • MOPAR OR NO CAR
70 F383-HP
« on: October 30, 2009 - 09:17:41 PM »
I am still looking for F383 HP motor. Cast date around July 1969 with a assembly date of early Nov.1969. Prefer a complete stock rebuildable motor but will consider all. I will consider trading my 440 for right motor.
JS27
1967 GTX
1970 Dodge Challenger R/T Conv.
Re: 70 F383-HP
« Reply #1 on: October 30, 2009 - 09:30:16 PM »
This is on Moparts, and maybe other pages too
ENGINES
1965--383 cast 6-7-65 block & steel crank 250.oo
1965 383 clean turns over dated 6-16-65 500.oo
1968--383 cast 12-28-67 assy 1-18-2 non h.p. block &steel crank
1969---383-cast3-3-69 assy 3-21-2 block&steel crank 250.oo
1969--383 cast 4-23-69 block& steel crank 250.oo
1970 383 dated 1-6-70 non h.p. shortblock 350.oo
1970 383 long block dated 10-10 69 H.P. -blockrods&steel crank 450.oo
1971--383 cast 4-19-71 non h.p.block only 250.oo
1971 --383 cast 11-18-71 non h.p. block & steel crank 250.oo
late model 440.short block, steel crank ,
from truck----siezed from sitting 350.oo
late model 440 ,short block, cast crank
siezed from sitting 250.oo
66 440 block .o4o over 150.oo
65 413 block dated 4-2-64 no caps 100.oo
62-67 383 iron intake #2205968 100.oo
67-69 440 intake # 2806178 i have the following dates
5-18-68
10-11-67
100.oo
66 440 intake # 2206000 100.oo
65 413 intake # 2206000 100.oo
68-9 383 h.p. intake #2806301
70 440 iron intake #2951736--dated8-23-69 125.oo
71 383 iron intake #2951666 100.oo
72 factory dual plane iron intake#3614014 25.oo
medium rise single plane alum intake 413-440-100.oo
VALVE COVERS
MAX WEDGE 4 BOLT NICE 150.OO
72 set 100.oo-blaseted primed
no 70s
oil pan # 402 -50.oo
big block water pump housings original iron diff cast #s avail.
67-70 383-hemi water pump housing #2780987--50.oo
big block power steering brackets 50.oo
big block pow st pump with brackets ,.blasted painted, 100.oo
big block 4 groove crank pulley for steel crank 40.oo
big block steel crank 2 groove crank pulley 40.oo
big block water pump pulley for steel crank motor
40.oo
air cond pulley and bracket for big block steel crank motor 40.oo
non h.p exh. manifolds 40.oo pr many to chosse from
stock rocker shafts 10.oo ea
stock rockers 10.oo-set
stock rocker spacers 10.oo-set
stock bolts and special spacers 10.oo set
mkyman@hotmail.com
Offline js27
  • MOPAR OR NO CAR
Re: 70 F383-HP
« Reply #2 on: November 15, 2009 - 06:31:27 PM »
Thanks Al I will check it out.
JS27
1967 GTX
wagesofsin
Re: 70 F383-HP
« Reply #3 on: November 15, 2009 - 06:35:55 PM »
not an f, but the guys a good pal of mine.
http://sarasota.craigslist.org/pts/1462593567.html
Offline torredcuda
  • Epping NH joined 11/23/03
Re: 70 F383-HP
« Reply #4 on: November 16, 2009 - 07:18:50 PM »
From Moparts-
70 383HP SHORTBLOCK...MOTOR IS STANDARD BORE AND SEIZED.STUCK FROM SITTING...NOT BEEN IN WATER OR OUTSIDE,JUST FROM SITTING.$150 603 209 1678
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline js27
  • MOPAR OR NO CAR
Re: 70 F383-HP
« Reply #5 on: November 17, 2009 - 12:04:59 PM »
Thanks for the info -the moparts is the wrong date code for what I need. Please keep the leeds coming.
JS27
1967 GTX
