Author Topic: sheet metal replacement order  (Read 2277 times)
Offline Jamie
« on: October 31, 2009 - 07:25:56 PM »
 :puke: :clueless:My 73 cuda basically needs it all in the back! roof skin .door skins.trunk.full quarters.left frame rail. extensions.My question is what parts to weld in first.does the roof overlap the upper quarter?should I skin the doors while the old quarters are on for body line exactness? I know this is a broad question but any experienced tips would help me .Thanks
I will finish a project.I will finish a project. I will finish a project.
70 barracuda plum crazy
( current goal is to keep just one car) AND FINISH IT!
08 charger r/t  w/road & track package
2011 silverado
wagesofsin
Re: sheet metal replacement order
« Reply #1 on: October 31, 2009 - 07:45:57 PM »
i would do the frame rail first.
if your going to do extensions, and trunk pans, invest in a cleco kit.
http://www.lowbucktools.com/clecos.html
this way you can place, and remove panels as you weld, replace them.
whatever body you have left , providing it still is showing body line, will remain.
do the 1/4s next, roof lays on top of the c pillars.
you can skin the doors last.
theres lots of posts on panel replacement here, just use the search function. and im sure im the first of many who will chime in.
look here, its not as in depth as id like it to be, but you will see what i mean about clecos.
hope it helps. and good luck.
http://usera.imagecave.com/Obituaries/challenger/
« Last Edit: October 31, 2009 - 07:54:09 PM by wagesofsin »
Offline Jamie
« Reply #2 on: October 31, 2009 - 08:12:44 PM »
Thanks for the info .my  cuda should look like the chally in the link once I rip apart.I am just doing alot of research before I dive in.as the plans to have a shop do this have changed (work has slowed).I do not want to rush in and make my car look like farmer ted welded some crap together!!!!!!!!!!!
2011 silverado
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #3 on: November 01, 2009 - 06:28:33 AM »
I agree,frame rails first.If the quarters are the originals leave the doors on and get the door to 1/4 gap/line set so when you install the new 1/4s they will be placed correctly.After the quarters are on then reskin the doors to match the quarter and rocker gaps/lines.Don`t forget to also have the trunk lid handy for making sure the opening is correct.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #4 on: November 01, 2009 - 10:12:18 PM »
 :iagree:Definately have your doors on the car to help with quarter alignment.  Also, record dimensions on everthing you can think of, then go back and take more dimensions and then go back and verify your dimensions are correct.  You will be glad you did.
Offline Jamie
« Reply #5 on: November 04, 2009 - 10:07:31 PM »
thanks for the replies. I will be out in the garage making notes on dimensions and gaps like a mad scientist!!!!!!!!!!!!
2011 silverado
Offline 426HEMI
« Reply #6 on: November 04, 2009 - 10:19:56 PM »
Take pics of everything as well.  If you are like me you think you will remember but then you go to sleep and forget what it looked like.  Not as good as I was a few years ago.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline Jamie
« Reply #7 on: November 11, 2009 - 10:45:04 PM »
I tried to find pictures of someone doing spot welds with a mig welder.I have started on the front inner fenders and need to make these spot welds and do not want a mess. Any pics?
2011 silverado
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #8 on: November 11, 2009 - 11:48:38 PM »
check out my site for spot weld pics.
« Last Edit: November 17, 2009 - 09:41:34 PM by E-Body Products »
