Author Topic: Opening a locked trunk  (Read 713 times)
Offline IndyCuda
« on: October 31, 2009 - 07:28:47 PM »
The trunk lock on my '72 Barracuda is shot and I cannot open it with a key. My friend said something about a bar running behind the plate light. Can anyone advise a good way of opening it or have a diagram?
Offline GoodysGotaCuda
Re: Opening a locked trunk
« Reply #1 on: October 31, 2009 - 09:35:42 PM »
If you remove the upper portion of the back seat you can see whats going on in there. Get your extensions out and remove the bolts for the trunk latch to the body.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Alaskan_TA
« Reply #2 on: October 31, 2009 - 10:30:48 PM »
It is faster to tape a standard screwdriver with a thin tip to a broomstick, insert the tip into the lock slot & twist.
No need to readjust the latch afterwards that way either.  :naughty:
« Reply #3 on: October 31, 2009 - 11:48:06 PM »
I wasn't sure if the challenger was the same as the 'cuda. i thought my cuda wouldn't turn with just a screwdriver. However it's been forever since i have had the stock latch in mine (electronic now)
1976 Dodge Warlock
« Reply #4 on: November 01, 2009 - 01:06:41 PM »
the filler neck can be removed to reach the lock rod
Offline IndyCuda
« Reply #5 on: November 01, 2009 - 03:16:21 PM »
Thanks yall.
