What hole does the heater control cable come out of?
Author Topic: What hole does the heater control cable come out of?  (Read 6828 times)
Offline ShelbyDogg
« on: November 01, 2009 - 10:05:37 PM »
For and A/C car.
I'm putting mine back in and want to put it in it's original hole.  A pic or just a description of the location will do.
Thanks
Offline 67vertman
  • Member since 9-23-2005
Re: What hole does the heater control cable come out of?
« Reply #1 on: November 01, 2009 - 10:40:57 PM »
Here is a pic from om here which shows a Callenger firewall.
« Reply #2 on: November 01, 2009 - 11:31:11 PM »
Wow, No guess work left there. Nice. :ylsuper:
Offline ShelbyDogg
« Reply #3 on: November 02, 2009 - 12:28:52 AM »
Thank you vertman!  I know about all of those holes already. But where does the heater temp control cable go through for a A/C car?  I see yours is an A/C car. Did you forget to mark that one?
« Reply #4 on: November 02, 2009 - 08:22:33 AM »
Looking at this pic Glennster posted it appears to sneak out the same opening as one of the evaporator tube.
Offline ShelbyDogg
« Reply #5 on: November 02, 2009 - 09:47:30 AM »
The cable does not come out of that hole as the evaporator tubes are tight up against the firewall with it's rubber mounting gasket.  I have an A/C car in storage. I can just go out and check it out next month if someone with an original A/C car doesn't chime in.
Thanks
Offline FY1 RT SE
« Reply #6 on: November 02, 2009 - 01:39:24 PM »
That sure looks like a 'Cuda firewall.  No Road Lamp hole on a Challenger.
« Reply #7 on: November 02, 2009 - 03:43:14 PM »
Rob,
  It comes thru by the lower right corner of the master cylinder plate.
« Last Edit: November 02, 2009 - 06:10:38 PM by MEK-Dangerfield »
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #8 on: November 02, 2009 - 07:36:07 PM »
 :clueless: What road lamp hole?  :dunno:
Go Fast & Have Fun...
Offline ksierens
    • 70 Challenger Resurrection
« Reply #9 on: November 02, 2009 - 07:39:56 PM »
That would be the hole below the "Reverse Light"
Kurt - SE Michigan
Offline ShelbyDogg
« Reply #10 on: November 02, 2009 - 07:47:59 PM »
Thanks Mike.
I just got back from my Dad's house, where I keep my car. I looked at that hole too. It came out under my clutch pedal retainer bracket just like in your picture. On someone's firewall pic, it is the one marked insulation retainers.  My car was an original non-A/C car that I added air to around 1985, so I wanted to check with a factory air owner. Thanks again.
« Last Edit: November 03, 2009 - 01:04:30 AM by ShelbyDogg »
« Reply #11 on: November 02, 2009 - 09:39:59 PM »
There's a clip that keeps it secured to the cowl lip edge.
Hard part to find as I don't think anyone is making it.
Offline 67vertman
« Reply #12 on: November 02, 2009 - 10:19:27 PM »
It is not my car, it was posted on here before and i kept it for reference.  However, I do believe it is for a Challenger.
I have one for a Cuda as well.
Offline ShelbyDogg
« Reply #13 on: November 03, 2009 - 12:58:40 AM »
I had the clip and also the rubber grommet that pushes through the firewall to seal the cable, I just couldn't remember what hole it came out of.  here is a pic of the clip and where it attaches.
Offline farmboy70
« Reply #14 on: November 03, 2009 - 07:41:02 AM »
Here are some pictures from my 71 R/T Challenger. I remember taking the inside one because I thought it was odd that the cable ran thru the insolation plug instead of it's own hole.
