Author Topic: removing E-brake  (Read 552 times)
Offline Canadian Cuda
removing E-brake
« on: November 02, 2009 - 12:08:42 AM »
i have a broken stud on the firewallside of the E- brake but don't know how to remove the cable :pullinghair:. i have all the body mounted bolts off and undid the clamp on the wire housing at the back. what am i missing ???. or do i need to remove including the cable :dunno: oh it's for a 70 cuda if that helps
Geoff
70 Cuda 440-4, auto, 8 3/4 sure-grip
Re: removing E-brake
« Reply #1 on: November 02, 2009 - 11:43:40 AM »
I leave the cable attached to the pedal & remove both as a unit & remove the cable from the pedal on the bench if you need to remove it at all
« Reply #2 on: November 02, 2009 - 03:47:26 PM »
that's what i ended up doing thanks chyrco :thumbsup:
Geoff
