Author Topic: Help - Need Pics - Throttle and Kickdown Bracket issues????  (Read 564 times)
Offline t1971Chally
« on: November 02, 2009 - 07:18:01 PM »
Hello everyone,
I am hoping that you guys can help me out.  I have a 71 challenger with a 440 engine, Edelbrock Torker intake, Edelbrock Thunder series AVS 1813 carb (that I just installed).  The problem I am having is with the Locar aftermarket kickdown cable bracket and the throttle cable bracket interfering with each other.  I was curious if anyone out there has a similar setup that could post pictures of the throttle bracket and kickdown bracket???? I am not sure if the throttle bracket is the correct one or if I need a different kick down bracket for the Lokar cable kickdown system.  Please help....I am stuck.  Other ideas are welcomed as well.
Thanks Ted
Ted
1971 Dodge Challenger 440 Magnum
:cheers:
Re: Help - Need Pics - Throttle and Kickdown Bracket issues????
« Reply #1 on: November 02, 2009 - 10:00:24 PM »
Here's a bump back up.  Maybe some can post a picture of their set up for you. I myself dont have that type
Offline quagmire
  • Traction Impaired......
« Reply #2 on: November 02, 2009 - 10:19:16 PM »
Here is a pic of mine during mock up way back when, the cables run parallel to each other.
