Author Topic: Valve train help!!!  (Read 476 times)
Offline gs69350
Valve train help!!!
« on: November 03, 2009 - 12:59:26 PM »
Hey all, thanks for the advice on my earlier post.
Parts are being ordered but I've run into an issue ordering valves and pushrods...
I do not have the stock spec's on the valves and when I look them up to order, I'm coming across several different lengths....
The heads are '72 "J" heads.  Currently the smaller 1.88" valve.
We will be converting to the 2.02"s and I need a part # or recommendation for a decent stainless steel set.  I need intake and exhaust.  (Most parts have already been ordered from summit, so a link to them would be awesome!)
I also need pushrods, as the are mysteriously gone.
I will be using the Lunati Voodoo 60402 cam, with their lifters, and 73949 Lunati valve springs.
Also, does anyone have a recommendation for main/rod bearing clearances that I should request from the machine shop?
Thanks!!!
