Author Topic: 6-Pak Carbs - Only Runs Well with Center one on  (Read 2338 times)
Offline cwestra
Re: 6-Pak Carbs - Only Runs Well with Center one on
« Reply #15 on: November 04, 2009 - 08:36:12 AM »
How long did the carbs sit before being installed to run?
Around a year.
Corey - in Northern Indiana
« Reply #16 on: November 04, 2009 - 08:37:25 AM »
looking at the pictures , i think they are either missing the mixture screws, or backed way out. This would cause you to adjust the idle screw on the center carb way up and idle high, and also run like crap.  those soft plugs pop right out pretty easy.
Offline Mike70
  • Future Challenger Pilot
« Reply #17 on: November 04, 2009 - 10:03:16 AM »
If those carbs are 30+ years old and have never had those plugs removed so the mixture screws and passages could be cleaned, there could be all kinds of crud built up.   :2cents:
70 Challenger RT/SE
(If I ever get it done - wait, I guess I have to start first).
Offline cwestra
« Reply #18 on: November 04, 2009 - 10:59:36 AM »
The screws are definately there.  I can see the pointed tips sticking through to the inside.  What's the best way to pop out those plugs?
Offline 426HEMI
« Reply #19 on: November 04, 2009 - 11:42:44 AM »
Try using a sharp pick and pop them out from the edge of them  :2thumbs:  On some of them that had the steel plugs you had to use a hack saw and cut on the corners of the carb to get them out.
But the soft plugs are much easier to get out. :bigsmile:
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #20 on: November 04, 2009 - 11:43:13 AM »
I drill a small hole from the bottom of the base plate on an angle towards the plugs to remove them
Offline 426HEMI
« Reply #21 on: November 04, 2009 - 11:52:28 AM »
That will work as well if they are hard to remove. The dint in the bottom of the plate is the bottom of the hole for the adjuster so go a littlebefore that to drill your hole.   :2thumbs:
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline cwestra
« Reply #22 on: November 04, 2009 - 12:11:37 PM »
Is this the area to drill?
« Last Edit: November 04, 2009 - 12:13:37 PM by cwestra »
« Reply #23 on: November 04, 2009 - 12:16:35 PM »
yes
Offline cwestra
« Reply #24 on: November 04, 2009 - 12:48:43 PM »
With original plugs in place, like mine are, does this mean the screws are completely closing the passage or were they set up to allow some flow?
« Reply #25 on: November 04, 2009 - 01:37:40 PM »
generally the screws are adjusted 1/2 -3/4 of a turn back from the closed off position
Offline 426HEMI
« Reply #26 on: November 04, 2009 - 01:43:51 PM »
 :iagree:  You got me first Neil.   :bigsmile:
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline 6packCuda
« Reply #27 on: November 04, 2009 - 02:16:30 PM »
When all 3 are on, I can't get the engine to idle below about 1,900 with idle screw backed out and it runs rough.  When I rev the engine it continues to be rough.  Can't tell if it's lean or rich.  When I swap out the outboards with the plates it make a huge difference.
When I bought the car 7 years ago it came with all original carbs but only the center was on the car.  Evidently he had issues with the outboards also.  My brother rebuilt the carbs during the restoration so I was expecting the problem to be gone.
The linkage for the outboards could just be adjusted wrong and is holding the butterflys open a little bit. That would cause the fast idle.
Offline cwestra
« Reply #28 on: November 04, 2009 - 02:23:06 PM »
I have them disconnected.  Good thought, though.
Offline cwestra
« Reply #29 on: November 04, 2009 - 05:14:00 PM »
I've attached 2 pictures of the throttle plates in these carbs.  Plates are in the fully closed position, yet they are not closing air off completely.  How well should the fit be here when they're shut?  Could this be the problem I'm having?
